Topic: ASIO driver 2.2 small issue (Read 493 times) previous topic - next topic
Hello,
I noted that when using ASIO driver 2.2 on the current FB v2 there is a small issue.
If the following track is not immediately available (e.g. on a sleeping HD for which FB is waiting for), the last chunk of what is in the ASIO driver buffer is repeated forever (until the new track is finally available and correctly played).
This (on my system) doesn't happen not using ASIO driver.
Regards
Andrea
Re: ASIO driver 2.2 small issue
Noted, will look into for next ASIO component update.
We are the bork. Your software bugs will be added to our own. Resistance is futile.
