Topic: JScript Panel (Read 182869 times) previous topic - next topic
Re: JScript Panel
Reply #1075
Hello!
Can you please tell how to remove "spaces" from sides of the Text Display panel?
And (maybe) make text scrollable?
(see screenshot comparison with old Text Display component).
Re: JScript Panel
Reply #1076
You can get rid of the left/right margins by adding this at the start of the script
LM = 0;
or
LM = _scale(2); // or some other low value, 5 is the default
The text should already be scrollable with your mouse wheel. That arrow is also clickable but more cumbersome.
Re: JScript Panel
Reply #1077
LM = 0;
Thanks, that worked, but only for left/right margin. What about top (it's more crucial)? =)
Scrolling doesn't work, but that maybe because of plugin Flowin, I guess (old one just shows scrollbar, though).
Re: JScript Panel
Reply #1078
Hi there Marc, sorry for unrelated Jscript post. In some of your post, I see your foobar actually use a different shade of dark RGB(19, 19, 19) background as seen on
toolbar header background, window background and also the stacked tabs. May I ask how to do that? Thank you.
Spoiler (click to show/hide)
Re: JScript Panel
Reply #1079
Darker colours come from using Default UI (top) as opposed to Columns UI (bottom).
Re: JScript Panel
Reply #1080
LM = 0;
Figured it out myself (if someone need it):
X
<code>
LM = 2;
HM = 16;
var text = new _text_display(LM, -HM, 0, 0);
function on_size() {
   panel.size();
   text.w = panel.w - (LM * 2);
   text.h = panel.h + HM * 2;
   text.size();
</code>
