Topic: How to select output channel on 32 channel interface?  (Read 845 times) previous topic - next topic
Hey, i am using a Antelope Orion32 with 32 output channels.
I did install the Wasapi output for Foobar2000, but there is no option to choose the output channel (17/18 in my case) . I can not use the standart output channel 1/2, as i need them for something else.
Is there any way to select output channel in Foobar?
Re: How to select output channel on 32 channel interface?
Should be possible through the ASIO component in custom channel mapping. I doubt Windows knows how to work with 32 channels.
I can not find channel mapping. Where does this sit?
"Output" should expand with doubleclick and show another page nested under it. There you create a channel mapping, which will show up as a new device.
Dude, thanks a million : D
Works. Nice!!
