Topic: NEW ESLyric v0.5 - an alternative lyric show component (Read 31590 times) previous topic - next topic
Re: NEW ESLyric v0.5 - an alternative lyric show component
Reply #103
enhanced lyrics = sync lyrics ?
https://github.com/ESLyric/release/wiki/%E6%AD%8C%E8%AF%8D%E6%BA%90%E5%8F%8A%E8%A7%A3%E6%9E%90%E5%99%A8%E8%84%9A%E6%9C%AC#:~:text=%E5%A4%9A%E6%A0%87%E7%AD%BE%E5%A2%9E%E5%BC%BALRC%20(%E8%A7%81wiki%20Enhanced%20format%E9%83%A8%E5%88%86%E8%AF%B4%E6%98%8E)
https://en.wikipedia.org/wiki/LRC_(file_format)
Thank you. I understand.
[00:00.00]line 1
[00:01.00]line 2
Lyric Processor can
[mm:ss.xx] <mm:ss.xx> line 1 word 1 <mm:ss.xx> line 1 word 2 <mm:ss.xx> ... line 1 last word <mm:ss.xx>
[mm:ss.xx] <mm:ss.xx> line 2 word 1 <mm:ss.xx> line 2 word 2 <mm:ss.xx> ... line 2 last word <mm:ss.xx>
Lyric Processor cannot
Reply #104
Background Image, is it possible to specify a folder as the Image source and target all images under the folder?
I would appreciate it if this could be done.
Reply #105
Just an FYI... If your theme is portable, ESLyric will not work if there is an apostrophe in your folder name. It won't even list or load sources.
Reply #106
My apologies. My mistake.
The image files in the folder were all in webp format.
I converted them to jpg and they displayed fine.
Reply #107
Good day guys,
First time posting  :)
I have a couple questions about ESLyrics:
I'm trying to set a background picture but I don't see the "panel preferences" as on the developer (picture #1) instead I see the one with the "display configuration" (picture #2), Am I missing something?, do I need another plugging to show it? (I'm running version 0.5.4.1028)
Second questions is, if is possible to have a second line to show when the lyrics is too long...Right now what it does is that it scrolls from right to left (I f I go to  "Desktop lyrics" (Picture #2) I have a field call "line(s) and there I can chose "single line" and "double line" but this make the Lyric that is coming in to show on the top line which is not ideal.
Thanks in advance for your help!
Best regards.
Reply #109
Good day guys,
Best regards.
The panel preferences you search is in the panel right click
X
Reply #110
Hello Paregistrase,
And thank you for the quick reply.
Sorry I did not say that I want the background for "desktop lyrics" not for the UI panel.
Reply #111
Hello Paregistrase,
I don't think that you can set a background, the whole point is that it is transparent to be able to see the lyrics over other things you're doing.
IMaybe you can use https://hydrogenaud.io/index.php/topic,90977.0.html to make a poup window with the lyrics. It is a bit fake solution but it can have background picture, and it is movable.X
The window with the lyrics can be moved, resized and have the same configurations of a lyrics panel inside foobar2000
Reply #112
Hello Paregistrase,
And thank you for the reply.
Reply #113
When Panel and Desktop Lyric are displayed at the same time,
Panel does not show the enhanced lyrics, but the Desktop Lyric does,
What does this mean?
This title I can't find any enhanced lyrics in "Search".
Reply #114
Sorry.
The panel has three "Karaoke modes".
Off
Always on
On when show enhanced lyric
For Desktop, Karaoke mode is either "Off" or "On".
Probably, Desktop  when "Karaoke mode" is "On".
If it is "sync lyrics", it shows "enhanced lyric".
I guess it is like that.
Reply #117
Found a memory leak bug. If the image artwork is turned on, foobar2000's memory climbs with every track that is played,
Reply #118
ESL has a internal images cache, and will do GC when necessary.
Reply #119
Ok, thanks! I changed pref.image.cache.limit from 16 to 1 and I noticed that around 1100mb the cache reset.
