Topic: Adaptive Lowpass in Rev6 of lame_dm?? (Read 4297 times) previous topic - next topic
I was doing some testing with lame_dm rev6 and I noticed on one of my files, a pure percussion .wav with lots of highhats and cymbals, that the lowpass numbers, usually 18671- 19205 INCREASED to 18774-19355.
I did not alter the --alt-preset normal commandline so my first question is:
1. Did Dibrom implement an adaptive lowpass?
2. If yes can one turn it on using switches? or does it only run internally?
3. If no, how did this happen?
4. Is there any other way to increase the lowpass to 18774 with other versions of lame or no? --lowpass width maybe?
My guess is that the different sample rate (48 vs 44.1) may have something to do with this.
/Andreas
:jawdrop: Doh!!!!!!!! I'm such a fool! :insane:
You are right!
Well now that I have embarrassed my self I might as well ask two more questions...
1.  Is implementing an adaptive lowpass possible? and advanatageous?
2.  Why are certain values fixed? For example who decided on 18671 for lowpass 19?  Can we edit the source code to make it 19000 for lowpass 19?
Anybody???
Yes, and Yes.  Can I do it?  Not currently.  But I think an adaptive lowpass could solve quite a few problems... I think this is one of the next *big* things that LAME needs..
Well part of the reason is because its not a hard lowpass.. the polyphase part for example.  It will cut off nearly completely around 19khz though.
I know there are things concerning ease of use, frontends, etc. that you want to change....BUT What other big things do you think Lame needs concerning QUALITY?
Well the adaptive lowpass for one, and a much better noise measuring system (better tonality estimation helps here) and method for determining best quantization... (this last part is what I'm messing around with myself at the moment..).  Some sort of better impulse detection would be nice also.. and a 2-pass mode for abr.
Naoki is also testing new noise shaping for Lame. One thing I wonder is that is the Lame's spreading function really optimal. It's said that it has been done using listening tests, but I wonder who were the testers.
Anyway if Naoki can make new noise shaping and the more difficult part - new tonality estimations to work, it could mean that achieving good quality/bitrate (profile tweking) becomes much more easier. Anyway, with optimal spreading function and tonality estimations, nearly optimal masking threshold and overall better simultaneous masking could be achieved.
Dibrom's current tweking is working pretty well, but even he thinks it's pretty roughly done, meaning that several special situations must be tweaked via code level forking, and this does lead to a bit non-optimal bitrates sometimes especially with some low volume music.
Juha Laaksonheimo
JohnV,
Any idea of a time frame on when Naioki might be finished with the new tonality estimation, etc?
I mean are we talking many months or just weeks?
