Topic: Media Library monitoring error (Read 2171 times) previous topic - next topic
Whenever I rip a cd with Exact Audio Copy, the artist name is not recognized and that the library monitoring goes in the Error! status. Here is the console output (notice the line "Folder watching failure: Invalid parameters"):
Added 13542 items
Changes merged into library
Watching: D:\Bibliothèques\Ma Musique
Watching: C:\musique-ipod-tracked
WSH Panel Mod (Art Reader by marc2003): Parsing file "C:\Users\Martin et Geneviève\AppData\Roaming\foobar2000\marc2003\common4.js"
WSH Panel Mod (Art Reader by marc2003): initialized in 696 ms
TouchRemote initialization started
TouchRemote database id: 51A16F4C1196B567
TouchRemote initialization finished
WSH Panel Mod (Art Reader by marc2003): initialized in 7 ms
w7shell: init started
w7shell: GDI+ initialized
w7shell: COM initialized
w7shell: running on Windows NT 6.1.7601 Service Pack 1
w7shell: DWM composition enabled
w7shell: WA_DISALLOW_PEEK successfully set
w7shell: WA_HAS_ICONIC_BITMAP successfully set
w7shell: WA_FORCE_ICONIC_REPRESENTATION successfully set
w7shell: WA_FLIP3D_POLICY successfully set
w7shell: all green
Filter 304 msec
Group 15 msec
Populate 57 msec
Startup time : 0:07.741686
Added 44 items
Modified 44 items
w7shell: taskbar button create notification got
Times: a0 - a1: 0msec
Times: a1 - a2: 0msec
Times: a2 - a3: 0msec
Times: a3 - a4: 2msec
Times: a4 - a5: 0msec
Synch: 4 msec (in mainthread!)
Seekbar: taking Direct3D9 path.
Seekbar: Frontend initialized.
Properties dialog refresh: 0:00.000192
Properties dialog display refresh: 0:00.002321
Modified 14 items
Properties dialog refresh: 0:00.001051
Properties dialog display refresh: 0:00.003384
Modified 14 items
Properties dialog refresh: 0:00.000153
Properties dialog display refresh: 0:00.001501
Modified 15 items
Properties dialog refresh: 0:00.001138
Properties dialog display refresh: 0:00.003858
Modified 15 items
I use version 1.2.2 with Win7 and here are my components:
Core (2013-01-18 15:31:20 UTC)
foobar2000 core 1.2.2
foo_abx.dll (2010-12-04 22:24:54 UTC)
ABX Comparator 1.3.4
foo_albumlist.dll (2013-01-18 15:30:04 UTC)
Album List 4.5
foo_autoupdate.dll (2010-12-24 15:51:31 UTC)
Automatic Updater 1
foo_burninate.dll (2011-08-27 22:07:37 UTC)
Audio CD Writer 3.0.3
foo_cdda.dll (2013-01-18 15:29:30 UTC)
CD Audio Decoder 3.0
foo_chronflow.dll (2010-11-27 18:21:16 UTC)
Chronial's Coverflow 0.3.0
foo_converter.dll (2013-01-18 15:29:34 UTC)
Converter 1.5
foo_dsp_eq.dll (2013-01-18 15:30:04 UTC)
Equalizer 1.0
foo_dsp_std.dll (2013-01-18 15:29:58 UTC)
Standard DSP Array 1.2
foo_dynamic_range.dll (2011-11-12 22:18:34 UTC)
Dynamic Range Meter 1.1.1
foo_facets.dll (2011-08-19 00:47:43 UTC)
Facets 1.0
foo_fileops.dll (2013-01-18 15:28:32 UTC)
File Operations 2.2
foo_freedb2.dll (2012-10-22 11:51:26 UTC)
Online Tagger 0.7
foo_hdcd.dll (2012-08-07 20:58:10 UTC)
HDCD decoder 1.15
foo_httpcontrol.dll (2013-01-08 20:59:24 UTC)
HTTP Control for FoobarCon 0.97.19-fc
foo_input_dvda.dll (2011-07-28 21:26:36 UTC)
DVD-Audio Decoder and Watermark Detector 0.4.8
foo_input_std.dll (2013-01-18 15:29:10 UTC)
Standard Input Array 1.0
foo_lyricsgrabber2.dll (2011-09-29 03:47:39 UTC)
Lyrics Grabber 2 0.5.5.2 beta
foo_masstag.dll (2012-12-03 01:55:10 UTC)
Masstagger 1.8.4
foo_monkeymote.dll (2012-12-13 14:59:40 UTC)
MonkeyMote 4 Foobar 2.2.5
foo_musicbrainz.dll (2012-08-27 22:04:05 UTC)
MusicBrainz Tagger 0.3
foo_out_asio.dll (2012-06-06 13:36:51 UTC)
ASIO support 2.1.2
foo_out_wasapi.dll (2012-12-15 03:31:23 UTC)
WASAPI output support 3.1
foo_playcount.dll (2012-11-02 23:39:38 UTC)
Playback Statistics 3.0.2
foo_playlist_revive.dll (2012-08-23 22:27:15 UTC)
Playlist Revive 0.2
foo_popup_panels.dll (2012-06-15 12:21:24 UTC)
Popup Panels 0.1.4
foo_prettypop.dll (2010-11-27 19:07:31 UTC)
Pretty Popup 1.2.5
foo_quicksearch.dll (2012-10-29 23:53:18 UTC)
Quick Search Toolbar 3.4
foo_quicktag.dll (2011-12-13 02:50:14 UTC)
Quick Tagger 1.0.3
foo_rgscan.dll (2013-01-18 15:29:44 UTC)
ReplayGain Scanner 2.1.2
foo_run.dll (2012-12-06 01:22:18 UTC)
Run services 0.3.7
foo_runcmd.dll (2012-12-03 01:56:05 UTC)
Run Command 1.1
foo_simplaylist.dll (2013-01-07 05:57:57 UTC)
SimPlaylist 1.0
foo_texttools.dll (2010-12-30 14:31:34 UTC)
Text Tools 1.0.5
foo_touchremote.dll (2012-03-22 07:38:36 UTC)
TouchRemote DACP server for foobar2000 0.2.8.3
foo_ui_columns.dll (2011-02-27 20:22:58 UTC)
Columns UI 0.3.8.8
foo_ui_std.dll (2013-01-18 15:29:12 UTC)
Default User Interface 0.9.5
foo_uie_biography.dll (2010-12-24 15:55:14 UTC)
Biography View 0.4.2.4
foo_uie_esplaylist.dll (2011-05-29 04:06:46 UTC)
EsPlaylist 0.1.3.9
foo_uie_lyrics3.dll (2012-11-12 22:33:46 UTC)
Lyric Show Panel 3 0.3.6 beta 5
foo_uie_wsh_panel_mod.dll (2012-10-25 13:28:34 UTC)
WSH Panel Mod 1.5.6
foo_utils.dll (2008-02-08 13:26:58 UTC)
Playlist Tools 0.6.2 beta 6
foo_verifier.dll (2010-11-27 20:15:47 UTC)
File Integrity Verifier 1.1
foo_vst.dll (2011-03-05 13:19:04 UTC)
VST 2.4 adapter 0.9.0.3
foo_w7shell.dll (2010-11-27 19:05:27 UTC)
Windows 7 integration 0.2.9.1
foo_wave_seekbar.dll (2012-11-12 00:08:04 UTC)
Waveform seekbar 0.2.29
