Topic: UPnP+Denon DNP-720: trying to play, get error “transition unavailable” (Read 4710 times) previous topic - next topic
I am using Denon DNP-720.
I have tried to play FLAC format file on my PC through Foobar2000 via Eithernet.
I can find playlist on UPnP lists. But there is error on my play saying " transition unavailable"
How can I fix this problem.
Plz help me.
With kind regards. Kim
You'd be better posting in the foobar2000 forum on here. I suspect you probably want the foo_upnp plugin?
Thank you for your response.
I am not familiar with this forum classification.
Sorry.  I have added foo_upnp plugin..
Thank u..
I renamed this and moved it in case you wanted to continue to use it as a place to discuss your issue, but apparently you don’t, because you then posted it another two times. Please don’t do that. I am closing this and your re-post of it; you can continue to seek help via your reply to the foo_upnp thread. Also, note that TOS #5 discourages double-posting, which does not equate to moving your thread as you said in its duplicate; if you want something moved or edited, please ask a moderator or administrator. Thanks, and welcome to HA!
