Topic: High bitrate formats experimental testing. (Read 41507 times) previous topic - next topic
SoundExpert testing engine is now fully operational and I am going to add hi-bitrate codecs. As the testing is “participation consuming” and the same time it has to be interesting in the results sense I suppose to add:
1.   SBC (A2DP, Bluetooth) 375 kbit/s (joint stereo)
2.   ATRAC3plus 256 kbit/s or ATRAC4.5 292 kbit/s
3.   MP3 256 kbit/s  or WMA  256 kbit/s or AAC 256 kbit/s
Also I am not sure about the particular codecs for the third point. Any suggestions and opinions would be helpful.
keeping audio clear together - soundexpert.org
[a href="index.php?act=findpost&pid=326593"][{POST_SNAPBACK}][/a]
I would be interested in AAC. The question is, which aac-lc encoder? QuickTime 7.02 have a 'vbr' lc-aac encoder. I think you should consider that one.
I would be interested in AAC. The question is, which aac-lc encoder? QuickTime 7.02 have a 'vbr' lc-aac encoder. I think you should consider that one.[a href="index.php?act=findpost&pid=326594"][{POST_SNAPBACK}][/a]
You mean aac-lc 256 from iTunes 5.0?
Use Atrac3plus because there is no software encoder for standard Atrac and thus no possibility to use it with any Sony hardware except Minidisc players.
[a href="index.php?act=findpost&pid=326596"][{POST_SNAPBACK}][/a]
Yeah. They are exactly the same encoder.
I would be interested in AAC....[a href="index.php?act=findpost&pid=326594"][{POST_SNAPBACK}][/a]
It seems to me that mp3_256 would be preferable because most people know its quality level and so it could be a kind of an ancor for all other codecs. Even it might be added to the system first for the purpose. Then other ones could be added and AAC as well. What mp3 codec to choose is still a question.
I would like to see Ogg Vorbis in testings but not the 1.0 version (as I see on the official site)  .
aoTuV b4 should be the right one.
Ogg Vorbis for music and speech [q-2.0 - q6.0]
FLAC for recordings to be edited
Speex for speech
Yes, de Mon, I am too. Finally all major codecs will be presented. But now I have to choose just a few one. The old codecs (like Ogg 1.0 or QDesign music 2) still be in system for comparison .... and memories.
I added first high bit-rate codec to SoundExpert:
mp3 CBR@256.1 (Audition 1.5) - MPEG-1 Layer 3 CBR, 256.1 kbit/s FBR
CODER: MP3/mp3PRO® Encoder for Adobe Audition 1.5
- Codec: Current - Best Quality
- Allow Mid-Side Joint Stereo: No
- Allow Intensity Joint Stereo: No
- Allow Narrowing of Stereo Image: No
- 44100 Hz Joint Stereo
DECODER: MAD 0.15.2b
It will play the role of "anchor" as it is stable and well known. All its test files were graded once by myself and the rating displayed is a kind of starting point. In other words the rating value be defined more precicely as volonteers will add their grades.
As I understood from the above posts the next candidates for inclusion are:
1. AAC 256 (CBR or VBR ?)
2. OggVorbis ~256
3. ATRAC3plus 256
and my personal desire - SBC (A2DP, Bluetooth) 375.
Any other proposals?
It will play the role of "anchor" as it is stable and well known.[a href="index.php?act=findpost&pid=337523"][{POST_SNAPBACK}][/a]
Honestly dude, you won't be taken even slightly seriously here if you don't use LAME - and at VBR!
Edit: BTW, SBC is known to be really godawful, maybe even worse than MP1 (yes, I mean it! MPEG audio layer one). So, if you really go with it, you might as well make it the low anchor.
Why not to include LAME. Don't see obstacles (and I'm not afraid to be taken here not seriously  )
[a href="index.php?act=findpost&pid=337525"][{POST_SNAPBACK}][/a]
Good chance to prove this.
- Allow Mid-Side Joint Stereo: No[a href="index.php?act=findpost&pid=337523"][{POST_SNAPBACK}][/a]
[a href="index.php?act=findpost&pid=337526"][{POST_SNAPBACK}][/a]
Well, I suppose he does have somewhat of a point there. Some FhG encoders mess up joint stereo, so when you go with high bitrates, it's better to use the headroom and use standard stereo instead.
Dunno if the FhG implementation in Audition has that issue though - specially because there are three of them!
Good chance to prove this.[a href="index.php?act=findpost&pid=337529"][{POST_SNAPBACK}][/a]
Well, you can read the specifications to get an idea.
Here they are:
[a href="https://www.bluetooth.org/foundry/adopters/document/A2DP_Spec_V1_0/en/]https://www.bluetooth.org/foundry/adopters/...P_Spec_V1_0/en/[/url]
Here they are:
[a href="index.php?act=findpost&pid=337531"][{POST_SNAPBACK}][/a]
Yes, I've got it. I also have Bluetooth headphones and software implementation of the codec. It sounds not bad. It seems to me that the comparison would be interesting.
Is it just me or did you specify turning on joint stereo once, and then turning it off twice ?  Also, can I ask why you want to use such an outdated encoder (ignoreing the questionable settings)?
ummh, why not use the one bundled with windows media player 10? (It's also FhG, and dated 2004)
you can set everything to yes and yet it still use stereo
If I'm not wrong, WMP10 (FhG ACM) will encode everything in stereo from 160kbps and above.
I think you should also include LAME --preset extreme, many use that, especially this forum
The coder used:
These are recomended settings for 256 CBR. To be true I'm not shure the output is "joint stereo" because only MAD decoder stated this while decoding.
The reasons why:
1. Audition is claimed (by itself though) to be PRO.
2. Its mp3/mp3PRO filter has many settings for both CBR/VBR and mp3/PRO (apart from eg. WMP 10)
3. It became "classic" already (as MM JukeBox also uses it) and hardly be tuned further in the future. "Anchor" indeed.
LAME --preset extreme. Are there any other setting proposals for the coder?
Hrm... maybe I should add "LAME Pro" to the new LAME homepage design. It won't make the slightest difference other than a warm fuzzy feeling in the users, but oh well...
LAME has many more settings for CBR/VBR.
LAME --preset extreme. Are there any other setting proposals for the coder?[a href="index.php?act=findpost&pid=337682"][{POST_SNAPBACK}][/a]
Tweaking is bad... mmmmmkay?
I tested this summer the "professional" version of Fraunhofer at 96 kbps. At this bitrate, it was well-known (understand: by tests older than Mathusalem) that LAME is uncompetitive against Fraunhofer encoders, especially the "Pro" ones.
http://www.hydrogenaudio.org/forums/index....pe=post&id=1654
more details: http://www.hydrogenaudio.org/forums/index....ndpost&p=314613
I wouldn't use Fraunhofer engine for a blind test competition.
 Ok. Let's say Fgh mp3 coder will be the "low anchor" in 256 coders group at SoundExpert. Realy better?  No problem. And its popularity is a sort of popularity of Latin among doctors.
Sorry?
I seriously doubt that any 256 kbps encoding could play the "low anchor" role. But if you insist, why not Blade instead?
But if your purpose is to directely compare MP3 to other (real) challengers, I strongly believe that LAME would be much more interesting to test than any Fraunhofer encoder.
[a href="index.php?act=findpost&pid=337697"][{POST_SNAPBACK}][/a]
LAME will be added for sure. I suppose: 3.97beta -V 0 --vbr-new ? (for 256 group).
It looks as the most consensual setting (I suppose) for this bitrate range. I'm not sure that it corresponds to 256 kbps encodings on average, but it's probably not far from this target.
For a chain of 9 SoundExpert test files 3.97beta -V 0 --vbr-new showed 217.3 kbps. I think it's ok for 256 group.
Should I add Lame first, choosing from:
1. AAC
2. ATRAC3plus
3. Lame
4. Ogg
