Topic: JScript Panel (Read 295806 times) previous topic - next topic
Re: JScript Panel
Reply #525
JScript Panel v2.5.3
code metadb = fb.GetFocusItem(); returns nothing.
Spoiler (click to show/hide)
How to solve this. An example is desirable.
UR5EQF. Ukraine
Re: JScript Panel
Reply #526
Radical idea: try a playlist that isn't empty.
Click the attachment for full size
Code is pretty much the same as above post...
https://github.com/marc2k3/foo_jscript_panel/blob/ae052b20dbb0f5148dfc05ddd119e646eff6cfa6/component/samples/complete/js/panel.js#L29-L47
Re: JScript Panel
Reply #527
Does not work.
Why.
I have some code.
Anyway a gift from me
// ==PREPROCESSOR==
// @name "emoticon"
// @author "kgena_ua"
// ==/PREPROCESSOR==
function RGB(r,g,b){
    return (0xff000000|(r<<16)|(g<<8)|(b));
var ww = 0, wh = 0;
var bgcolor = RGB(128, 166, 255);
var bgcolor = RGB(0, 128, 192);
var color_1 = RGB(255, 255, 0);
var color_2 = RGB(0,0,0);
var img = create_emoticon(color_1, color_2);
var emoticon_s = 60;
var emoticon = resize_img(create_emoticon(color_1, color_2), emoticon_s, emoticon_s);
function resize_img(img, w, h){
    if (!img) return;
    var scale_w = w / img.Width;
    var scale_h = h / img.Height;
    var scale = Math.min(scale_w, scale_h);
    var iw = Math.round(img.Width * scale);
    var ih = Math.round(img.Height * scale)
    var temp_bmp = gdi.CreateImage(iw, ih);
    var temp_gr = temp_bmp.GetGraphics();
    temp_gr.SetSmoothingMode(2);
    temp_gr.SetInterpolationMode(7);
    temp_gr.DrawImage(img, 0, 0, iw, ih, 0, 0, img.width, img.height);
    temp_bmp.ReleaseGraphics(temp_gr);
    return temp_bmp;
    temp_bmp.Dispose();
    temp_gr = null;
    temp_bmp = null;
function create_emoticon(c1, c2){
    var temp = gdi.CreateImage(200, 200);
    var temp_gr = temp.GetGraphics();
        temp_gr.SetSmoothingMode(4);
        r = 90;
        d = r * 2;
        x = r;
        y = r;
        ys = y - r * 0.3;
        rs = r * 1.15;
        rs1 = rs * 0.73;
        rs2 = rs1 * 0.95;
        rs3 = rs1 * 1.1;
        rs4 = rs2 * 0.9;
        angl1 = 120;
        angl2 = 240;
        steps = 360;
        var dyP1 = 0;
        temp_gr.FillEllipse(x - d /2, y - d /2, d, d, c1);
        for (var j = angl1; j < angl2; j++) {
            xP1 = (rs1 * Math.cos(Math.PI * j / steps * 2 - Math.PI / 2));
            yP1 = (rs1 * Math.sin(Math.PI * j / steps * 2 - Math.PI / 2));
            xP2 = (rs2 * Math.cos(Math.PI * j / steps * 2 - Math.PI / 2));
            yP2 = (rs2 * Math.sin(Math.PI * j / steps * 2 - Math.PI / 2));
            if (j > angl1 && j < 180) dyP1 = dyP1 + 0.15;
            if (j > 180 && j < angl2) dyP1 = dyP1 - 0.15;
            temp_gr.DrawLine(x + xP1, ys + yP1 + dyP1, x + xP2, ys + yP2, 2, c2);
        for (var j = angl1; j < angl1 + rs * 0.02; j++) {
            xP1 = (rs3 * Math.cos(Math.PI * j / steps * 2 - Math.PI / 2));
            yP1 = (rs3 * Math.sin(Math.PI * j / steps * 2 - Math.PI / 2));
            xP2 = (rs4 * Math.cos(Math.PI * j / steps * 2 - Math.PI / 2));
            yP2 = (rs4 * Math.sin(Math.PI * j / steps * 2 - Math.PI / 2));
            temp_gr.DrawLine(x + xP1, ys + yP1, x + xP2, ys + yP2, 2, c2);
        for (var j = angl2 - rs * 0.02; j < angl2; j++) {
        temp_gr.FillEllipse(x + r * 0.15, y - r * 0.55, d * 0.12, d * 0.25, c2);
        temp_gr.FillEllipse(x - r * 0.4, y - r * 0.55, d * 0.12, d * 0.25, c2);
        lw = r * 0.08;
        temp_gr.DrawEllipse(x - d /2 + lw / 2, y - d /2 + lw / 2, d - lw, d - lw, lw, c2);
    temp.ReleaseGraphics(temp_gr);
    return temp;
    temp.Dispose();
    temp_gr = null;
    temp = null;
function on_paint(gr) {
    !window.IsTransparent && gr.FillSolidRect(0, 0, ww, wh, bgcolor);
    gr.DrawImage(emoticon, ww / 2 - emoticon_s / 2, wh / 2 - emoticon_s / 2, emoticon.width, emoticon.Height, 0, 0, emoticon.width, emoticon.Height, 0, 255);
    on_mouse = true;
    window.SetCursor(32649);
    window.Repaint();
function on_mouse_leave() {
    on_mouse = false;
    window.SetCursor(32512);
    window.Repaint();
function on_size(){
    ww = window.Width;
    wh = window.Height;
UR5EQF. Ukraine
Re: JScript Panel
Reply #528
You might recognise this script considering it's YOURS.
Also, this other person in YOUR THREAD is running YOUR SCRIPT in JSP 2.5.3 just fine with a little fix for radio streams...
https://hydrogenaud.io/index.php?topic=114686.msg994823#msg994823
Re: JScript Panel
Reply #529
In fact of the matter.
This is my mistake somewhere.
Some kind of mysticism
From my
foo_vis_vumeter is required
// ==PREPROCESSOR==
// @name "Peak meter 6Е5С"
// @version "102020"
function RGB(r,g,b) {
var font = gdi.Font("Arial", 11, 0);
DT_LEFT = 0x00000000;
DT_CENTER = 0x00000001;
DT_VCENTER = 0x00000004;
DT_SINGLELINE = 0x00000020;
DT_NOPREFIX = 0x00000800;
var ww, wh;
var on_mouse = false;
var VUMOffset_t;
var wheel = false;
var tooltip_timer;
ColorTypeCUI = {
    text: 0,
    selection_text: 1,
    inactive_selection_text: 2,
    background: 3,
    selection_background: 4,
    inactive_selection_background: 5,
    active_item_frame: 6
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
function get_color(){
    try {
        if (window.InstanceType == 0){
            bgcolor = window.GetColorCUI(ColorTypeCUI.background);
            c1 = window.GetColorCUI(ColorTypeCUI.inactive_selection_text);
            c2 = window.GetColorCUI(ColorTypeCUI.text);
            c3 = window.GetColorCUI(ColorTypeCUI.selection_text);
        } else if (window.InstanceType == 1) {
            bgcolor = window.GetColorDUI(ColorTypeDUI.background);
            c1 = window.GetColorDUI(ColorTypeDUI.highlight);
            c2 = window.GetColorDUI(ColorTypeDUI.text);
    } catch(e){};
    try {
            bgcolor = window.GetColourCUI(ColorTypeCUI.background);
            c1 = window.GetColourCUI(ColorTypeCUI.inactive_selection_text);
            c2 = window.GetColourCUI(ColorTypeCUI.text);
            bgcolor = window.GetColourDUI(ColorTypeDUI.background);
            c1 = window.GetColourDUI(ColorTypeDUI.highlight);
            c2 = window.GetColourDUI(ColorTypeDUI.text);
    } catch(e){};
    window.Repaint();
get_color();
function on_colors_changed(){
    get_color();
var dll;
var is_dll = utils.CheckComponent("\\user-components\\foo_vis_vumeter\\foo_vis_vumeter");
if (is_dll) {dll = false} else {dll = true};
if (dll) {VUMeter = new ActiveXObject("VUMeter")};
if (dll) {VUMeter.RegisterWindow(window.ID)};
function ToDB(Level){
    return Math.round(2000*Math.log(Level)/Math.LN10)/100;
var panel_on = true;
var x = window.Width / 2;
var y = window.Width / 2;
var steps = 360;
var r1 = window.GetProperty("radius", 50);
var r2 = r1 * 0.5;
var d1 = r1 * 2;
var d2 = r2 * 2;
var scale_on = window.GetProperty("scale on", true);
var c2 = RGB(0, 255, 127);
var c1 = combineColors(c2, RGB(255, 255, 255), 0.7)
var c3 = combineColors(c2, bgcolor, 0.5)
var color = [];
for(var j = 0; j < 10; j++) {
    color.push(combineColors(c1, bgcolor, j / 10)); /// bgcolor
var anglLP = 0;
var anglRP = 0;
var anglLP_p = 180;
var anglRP_p = 180;
var anglLP_stop = 180;
var anglRP_stop = 180;
var Lk = Rk = 0;
    // if (panel_on && fb.IsPlaying && dll) {
    if (dll && panel_on) {
        L = VUMeter.LeftLevel;
        R = VUMeter.RightLevel;
        LM = VUMeter.LeftPeak;
        RM = VUMeter.RightPeak;
        for (var i = 180; i < 360; i++) {
            xP1 = (r1 * Math.cos(Math.PI * i / steps * 2 - Math.PI / 2));
            yP1 = (r1 * Math.sin(Math.PI * i / steps * 2 - Math.PI / 2));
            xP2 = (r2 * Math.cos(Math.PI * i / steps * 2 - Math.PI / 2));
            yP2 = (r2 * Math.sin(Math.PI * i / steps * 2 - Math.PI / 2));
            LP = ToDB(LM);
            //LP = -99;
            wwwLP = Math.pow(10, (LP + 100) / 50);
            //anglLP = Math.round(180 + (wwwLP * 130 / 100));
            anglLP = 180 + Math.round(wwwLP * 130 / 100);
            if (anglLP > 180 || anglLP_p > 190) {
                if (anglLP_stop > 180){  // stop or pause
                    anglLP_stop = anglLP_stop > 180 ? anglLP_stop - 0.02 : 180;
                    anglLP = Math.round(anglLP_stop);
                if (anglLP > i){
                    c =  i < 310 ? c2 : c1;
                    gr.DrawLine(x + xP1, y + yP1, x + xP2, y + yP2, 2, c);
                if (wwwLP > 0 && anglLP_p >= anglLP){
                    Lk = Lk * 1.0005;
                    anglLP_p = anglLP_p - Lk;
                } else {
                    Lk = 0.005;
                    anglLP_p = anglLP;
                //anglLP_p = wwwLP > 0 && anglLP_p >= anglLP ? anglLP_p - 0.005 : anglLP;
                if (Math.round(anglLP_p) == i){
                    gr.DrawLine(x + xP1, y + yP1, x + xP2, y + yP2, 3, c);
            xL1 = ((r1 + 8) * Math.cos(Math.PI * i / steps * 2 - Math.PI / 2));
            yL1 = ((r1 + 8) * Math.sin(Math.PI * i / steps * 2 - Math.PI / 2));
            xL2 = ((r1 + 4) * Math.cos(Math.PI * i / steps * 2 - Math.PI / 2));
            yL2 = ((r1 + 4) * Math.sin(Math.PI * i / steps * 2 - Math.PI / 2));
            LL = Math.pow(10,((ToDB(L) + 100) / 50));
            anglLL = Math.round(180 + (LL * 180 / 100))
            if (anglLL > i){
                gr.DrawLine(x + xL1, y + yL1, x + xL2, y + yL2, 2, c3);
        for (var j = 0; j < 180; j++) {
            xP1 = (r1 * Math.cos(Math.PI * j / steps * 2 - Math.PI / 2));
            yP1 = (r1 * Math.sin(Math.PI * j / steps * 2 - Math.PI / 2));
            xP2 = (r2 * Math.cos(Math.PI * j / steps * 2 - Math.PI / 2));
            yP2 = (r2 * Math.sin(Math.PI * j / steps * 2 - Math.PI / 2));
            RP = Math.round(ToDB(RM));
            wwwRP = Math.pow(10, (RP + 100) / 50);
            anglRP = 180 - Math.round(wwwRP * 130 / 100);
            if (anglRP < 180 || anglRP_p < 160) {
                if (anglRP_stop < 180){  // stop or pause
                    anglRP_stop = anglRP_stop < 180 ? anglRP_stop + 0.02 : 180;
                    anglRP = Math.round(anglRP_stop);
                if (anglRP < j){
                    c =  j > 50 ? c2 : c1;
                if (wwwRP > 0 && anglRP_p <= anglRP){
                    Rk = Rk * 1.0005;
                    anglRP_p = anglRP_p + Rk;
                } else {
                    Rk = 0.005;
                    anglRP_p = anglRP;
                //anglRP_p = wwwRP > 0 && anglRP_p <= anglRP ? anglRP_p + 0.005 : anglRP;
                if (Math.round(anglRP_p) == j){
            xL1 = ((r1 + 8) * Math.cos(Math.PI * j / steps * 2 - Math.PI / 2));
            yL1 = ((r1 + 8) * Math.sin(Math.PI * j / steps * 2 - Math.PI / 2));
            xL2 = ((r1 + 4) * Math.cos(Math.PI * j / steps * 2 - Math.PI / 2));
            yL2 = ((r1 + 4) * Math.sin(Math.PI * j / steps * 2 - Math.PI / 2));
            RL = Math.pow(10,((ToDB(R) + 100) / 50));
            anglRL = Math.round(180 - (RL * 180 / 100))
            if (anglRL < j){
        th = gr.CalcTextHeight("0", font);
        for (var i = 0; i < 360; i++) {
            if (scale_on){
                xPt = ((r1 + 17) * Math.cos(Math.PI * i / steps * 2 - Math.PI / 2));
                yPt = ((r1 + 17) * Math.sin(Math.PI * i / steps * 2 - Math.PI / 2));
                if (i == 351 || i == 9){
                    tw = gr.CalcTextWidth(" 6", font);
                    gr.GdiDrawText(" 6", font, c2, x + xPt - tw / 2, y + yPt - th / 2, tw, th, DT_SINGLELINE | DT_CENTER | DT_VCENTER);
                if (i == 329 || i == 31){
                    tw = gr.CalcTextWidth(" 3", font);
                    gr.GdiDrawText(" 3", font, c2, x + xPt - tw / 2, y + yPt - th / 2, tw, th, DT_SINGLELINE | DT_CENTER | DT_VCENTER);
                if (i == 310 || i == 50){
                    tw = gr.CalcTextWidth(" 0", font);
                    gr.GdiDrawText(" 0", font, c2, x + xPt - tw / 2, y + yPt - th / 2, tw, th, DT_SINGLELINE | DT_CENTER | DT_VCENTER);
                if (i == 293 || i == 67){
                    tw = gr.CalcTextWidth(" -3", font);
                    gr.GdiDrawText(" -3", font, c2, x + xPt - tw / 2, y + yPt - th / 2, tw, th, DT_SINGLELINE | DT_CENTER | DT_VCENTER);
                if (i == 266 || i == 94){
                    tw = gr.CalcTextWidth(" -9", font);
                    gr.GdiDrawText(" -9", font, c2, x + xPt - tw / 2, y + yPt - th / 2, tw, th, DT_SINGLELINE | DT_CENTER | DT_VCENTER);
                if (i == 232 || i == 128){
                    tw = gr.CalcTextWidth("-20", font);
                    gr.GdiDrawText("-20", font, c2, x + xPt - tw / 2, y + yPt - th / 2, tw, th, DT_SINGLELINE | DT_CENTER | DT_VCENTER);
                if (i == 193 || i == 167){
                    tw = gr.CalcTextWidth("-50", font);
                    gr.GdiDrawText("-50", font, c2, x + xPt - tw / 2, y + yPt - th / 2, tw, th, DT_SINGLELINE | DT_CENTER | DT_VCENTER);
        gr.DrawLine(x, y - r1 - 8, x, y + r1 + 8, 2, bgcolor); /// bgcolor
        gr.DrawEllipse(x - r2 + 5, y - r2 + 5, d2 - 10, d2 - 10, 2, c3);
        if (wheel) {
            VUMOffset_t = Math.round(VUMeter.Offset) + " db";
            th = gr.CalcTextHeight(VUMOffset_t, font);
            tw = gr.CalcTextWidth(VUMOffset_t, font);
            gr.GdiDrawText(VUMOffset_t, font, c2, x - tw / 2, y - th / 2, tw, th, DT_SINGLELINE | DT_CENTER | DT_VCENTER);
function on_playback_stop(reason) {
    anglLP_stop = anglLP;
    anglRP_stop = anglRP;
    window.Repaint();
function on_playback_pause(state) {
    //pause = state;
    window.Repaint();
function on_size() {
    ww = window.Width;
    wh = window.Height;
    x = ww / 2;
    y = wh / 2;
function on_mouse_move(x,y) {
    on_mouse = true;
    on_mouse = false;
function on_mouse_wheel(step) {
    wheel = true;
    VUMeter.Offset = VUMeter.Offset + step;
    tooltip_timer && window.ClearTimeout(tooltip_timer);
    tooltip_timer = window.SetTimeout(function() {
        wheel = false;
    }, 2000);
function combineColors(c1, c2, f){ // When fraction is 0, result is 100% color1, when f is 1, result is 100% color2.
    var c1 = toRGB(c1);
    var c2 = toRGB(c2);
    var r = Math.round(c1[0] + f * (c2[0] - c1[0]));
    var g = Math.round(c1[1] + f * (c2[1] - c1[1]));
    var b = Math.round(c1[2] + f * (c2[2] - c1[2]));
    return (0xff000000 | (r << 16) | (g << 8) | (b));
function toRGB(d){ // convert back to RGB values
    var d = d-0xff000000;
    var r = d >> 16;
    var g = d >> 8 & 0xFF;
    var b = d & 0xFF;
    return [r,g,b];
function print(msg) {
    try {
        fb.trace(msg);
    } catch(e){console.log(msg);};
function on_playback_starting(cmd, is_paused){
    anglLP_stop = 180;
    anglRP_stop = 180;
    anglLP_p = 180;
    anglRP_p = 180;
    window.Repaint();
UR5EQF. Ukraine
Re: JScript Panel
Reply #530
Well just in case you've not realised the change I made for radio streams, it's fb.TitleFormat Eval no long accepts a boolean "force" parameter. You can no longer write code like
fb.TitleFormat("%blah%").Eval(true);
it must be changed to
fb.TitleFormat("%blah%").Eval();
This was in the changelog/breaking changes when v2.3.0 was released a very long time ago.
Re: JScript Panel
Reply #531
Playback: STOP.
metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();   works in Playlist switcher
but if use Album List Panel...
X
UR5EQF. Ukraine
Re: JScript Panel
Reply #532
So what you want is on_selection_changed and fb.GetSelection / fb.GetSelections. Read the docs.
on_item_focus_change / fb.GetFocusItem have always been playlist only regardless of component (JScript Panel/WSH panel mod/WSH panel mod plus/Spider Monkey Panel etc)
It wouldn't normally work from a playlist switcher except many people call on_item_focus_change from within on_playlist_switch.
Re: JScript Panel
Reply #533
Why in wsh panel mod  it works.
And it worked in older versions in jscript panel .
UR5EQF. Ukraine
Re: JScript Panel
Reply #535
No, fb.GetFocusItem has never worked from album list in ANY component
What.
I use wsh panel mod to create scripts. Works fine.
foo_jscript_panel-2.1.8.  Works fine.
UR5EQF. Ukraine
Re: JScript Panel
Reply #536
1) make sure your active playlist is empty so there is no danger of any playlist item being picked up by fb.GetFocusItem()
2) add this code to WSH panel mod
function on_selection_changed() {
    var metadb = fb.GetFocusItem();
    if (metadb == null) fb.trace("it's always been null you dumb ass");
    else fb.trace("metadb ok ", metadb.Path);
3) watch the console as you select different items in album list
Re: JScript Panel
Reply #537
wsh_panel_mod
function on_selection_changed(metadb) {
    on_item_focus_change();
X
and on foo_jscript_panel-2.1.8.  Works fine.
it was not always empty, ... I can't write to a stranger
UR5EQF. Ukraine
Re: JScript Panel
Reply #538
foo_jscript_panel v 2.5.3
X
UR5EQF. Ukraine
Re: JScript Panel
Reply #539
foo_jscript_panel v2.1.8
X
UR5EQF. Ukraine
Re: JScript Panel
Reply #540
what answer to the stupid asshole
UR5EQF. Ukraine
Re: JScript Panel
Reply #541
Please try to maintain a decent conversation, thanks
Re: JScript Panel
Reply #543
so we will install the old working functions that did not seem to existfb.
has never ...
EnableMenuItem never too
UR5EQF. Ukraine
Re: JScript Panel
Reply #544
so we will install the old working functions that did not seem to exist.
has never ...
UR5EQF. Ukraine
Re: JScript Panel
Reply #545
## v2.5.4
- Fix bug where the `cookie` returned by `gdi.LoadImageAsync` wasn't always unique.
- A recent website update broke the `Allmusic` sample. This is now fixed.
https://github.com/marc2k3/foo_jscript_panel/releases
Re: JScript Panel
Reply #546
v2.5.5 https://github.com/marc2k3/foo_jscript_panel/releases
The included Album art sample can now display front covers in radio streams if using fb2k v1.6.6. Tested with RadioParadise as per this thread
https://hydrogenaud.io/index.php?topic=120855.0
https://radioparadise.com/listen/stream-links
Re: JScript Panel
Reply #547
v2.5.5.1 https://github.com/marc2k3/foo_jscript_panel/releases
- The `on_playback_dynamic_info_track` callback now receives a `type` as the first argument. It will have a value of `0` for stream title updates and a value of `1` for stream album art updates.
Re: JScript Panel
Reply #548
Hi Marс2003, please tell me the difference between this application and Spider Monkey Panel (foo_spider_monkey_panel), which is based on your scripts, which one is preferable to use and why?
