Topic: Audio Unit inside layout txt (Read 1873 times) previous topic - next topic
Hi @Peter
It's very cool that with the new preview version, we can add audio unit inside layout now. But it seems the embedded AU is unconnected with the AU of same name in the active DSP chain? They're two separate instances. As opposed to View > DSP > plugin-name, which actually shows the plugin that is in the DSP chain.
Second, changing things in the embedded AU has no effect on the sound. Is this intended to be for visual (readout) only?
Third, the changelog mentions >>Added "Visualize with Audio Unit"<< What does this do? Is this in the settings somewhere? I cannot find it.
Thanks for the cool work you are doing
Re: Audio Unit inside layout txt
Followup:
I found  "Visualize with Audio Unit". It's under View menu > Visualizations. Sorry about that.
A small bug with embedded AU: it does not remember the preset I chose. It always reverts to the default on app restart.
General problem with Audio Units or VSTs inside foobar2000 is that you can either visualize accurately (feed live audio being heard) or control settings and feed audio being processed by this instance of the AU/VST (choppy/lagged performance of AU/VST that shows audio being played).
I just added (build 2024-07-04) a separate, probably more useful mode: add mode=control to the layout line - audio data being fed isn't synchronized with playback but changes in AU settings are applied to current DSP configuration.
This is nice. There's a small bug in that the embedded AU sometimes forgets its size and I have to resize it and the panel that contains it.
AU aside, there's an odd bug. This AU-free layout
splitter vertical style=thin
 splitter horizontal style=thin
  tabs position=top
   splitter horizontal style=thin tab-name="Playlists"
    playlist-picker
    albumart type="front cover"
   albumlist tab-name="Library"
   splitter horizontal style=thin tab-name="Info"
    selection-properties sections="General"
    console mode=lite
  refacets
   playlist
   playback-controls
has playback-controls on the right side of a vertical split. This causes the left pane to resize itself to take up half the window no matter how you move the splitter.
OTOTH this layout
    tabs position=top
      playlist-picker
      console mode=lite
   refacets
   playlist
 playback-controls
which is almost identical but puts the playback-controls at the bottom and lets it take up the whole width of the window, is ok. It's as if having playback-controls this way properly constrains the left pane.
I think this bug was fixed one or two previews ago and regressed with the 2024-07-08 version
Where does one find a guide to the syntax used in the layout editor?
