Topic: Foobar playlist jumping randomly (Read 1233 times) previous topic - next topic
Hello, i use foobar since long.
It works fine for me
however, the other day i selected random play order, playback>order>random
later that day i reverted to default order.
Since then, the play order has changed somehow.
it does not follow the playlist, it jumps to the end, or almost there, (in a list of 10 songs for example).
and then continues to the end, not playing many of the songs in the list.
I uninstalled foobar, and removed user files, then installed again. But the wrong behaviour continues.
I wonder what can i do, to fix it.
I hope you can help me. thanks.
Re: Foobar playlist jumping randomly
You could make playback order visible in the toolbar to confirm selection.
You could look at the console and see if it contains clue. Player would scrolled through the unplayed songs if their location was not found.
Other than above, you could provide standard troubleshooting info. At the least:
Foobar2000 Version
Components installed
Hello thanks.
windows 7 64 bits recently updated.
latest foobar2000, 1.3.17
Default installation, no additional plugins installed.
Not played songs are not depreciated bc of the location was not found, as this songs are played when i correct the order or directly play them.
How do i make playback order visible in the toolbar?
As i write this text, i made a list and it happened again, foobar jumped to the end of the playlist, them jumped back some items back like it could happen if it were in random order, but its not.
The log shows nothing special, if you want to parse it i can append it.
Right click toolbar and select playback order
Any help on this? my playlist keeps jumping ramdomly no matter i have the play order in default
thanks
Preferences -> Components. Copy report. Paste between a code tag on a reply. Also sharing whatever configuration you've added since installing would be helpful.
Hello thanks.
About configuration changes i think i have registered file types, and set enqueue as default action, nothing else.
Core (2017-11-24 08:00:06 UTC)
    foobar2000 core 1.3.17
foo_albumlist.dll (2017-11-24 07:58:40 UTC)
    Album List 4.5
foo_cdda.dll (2017-11-24 07:58:36 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2017-11-24 07:58:34 UTC)
    Converter 1.5
foo_dsp_eq.dll (2017-11-24 07:58:56 UTC)
    Equalizer 1.2
foo_dsp_std.dll (2017-11-24 07:58:42 UTC)
    Standard DSP Array 1.3.1
foo_fileops.dll (2017-11-24 07:57:40 UTC)
    File Operations 2.2.2
foo_freedb2.dll (2017-11-24 07:57:34 UTC)
    Online Tagger 0.7
foo_input_std.dll (2017-11-24 08:23:10 UTC)
    FFmpeg Decoders 3.2.4
    Standard Input Array 1.0
foo_rgscan.dll (2017-11-24 08:03:34 UTC)
    ReplayGain Scanner 2.2.2
foo_ui_std.dll (2017-11-24 07:58:50 UTC)
    Default User Interface 0.9.5
foo_unpack.dll (2017-11-24 07:58:40 UTC)
    ZIP/GZIP/RAR Reader 1.8
Under Playback, check that Playback Follows Cursor isn't checked. Otherwise, instead of following the playlist order, foobar will just play whatever song is highlighted, and proceed from there.
I didnt realize that was the function of that setting!
it was so simple thanks!
solved.
LOL. This should be sticky, seriously. And congratulations for @Climhazzard1997 for perfect expertise!
