Topic: HLS: Two hour delay with internal decoder on specific streams. (Read 1977 times) previous topic - next topic
I've encountered a strange bug/behaviour with HLS streams from the Swedish national radio, e.g. this one (hope this one works outside Sweden):
https://live.sr.se/pool1/p4kristianstad/p4kristianstad.isml/p4kristianstad-audio=192000.m3u8
If I play it with the internal decoder it will play the audio from two hours ago, while if I use FFmpeg through the FFmpeg rrapper it will output the correct audio, confirmed with the official site (www.sverigesradio.se/kristianstad, the "Lyssna direkt" button).
I'm using 1.6.7 beta 13.
Re: HLS: Two hour delay with internal decoder on specific streams.
That would be because their stream playlist starts at a certain checkpoint of buffering, but there's some sort of metadata that indicates where the "live" position should be relative to the start of the list. Hopefully your HLS stream isn't geoblocked, that should help with Peter implementing this functionality, assuming he hasn't started something already, having seen this before I did.
(Incidentally, my seeing it doesn't benefit the development anyway, since I'm not involved in core development. I really only just keep the forums relatively tidy, and occasionally poke into my own dev stuff.)
Yes, I guessed it was something like that. I hope it gets implemented, I suspect that more streams than these use this feature. A side note that may or may not be of help is that it works in VLC.
A nice bonus would of course be the ability to seek in streams like these, but that might be hard to implement.
Seeking in streams with backlog available would require inputs to be able to report their "current" playback position. I admit, this would also be a nice thing to have for formats that support looping, to report the "actual" stream position as they loop indefinitely.
Any progress on this issue?
The issue persists in v1.6.9.
It may be a short while, as Peter told me he's currently busy with a backlog of paid work he was putting off or something. It may be interesting work to Mac users.
I also hear 30 minutes of time shift back in time when listening to HLS streams from Danish Radio using internal HLS decoder. One example: DR P4 Fyn
This requires parsing the HLS playlist for a tag indicating the current playback position. And starting at a non-zero playback position would also require that inputs be able to report an arbitrary file decode position. For instance, parsing the HLS playlists periodically and detecting when the older entries are removed and thus change the available backlog.
Problem acknowledged and being addressed, thanks for reporting.
Fixed in 1.6.10 beta 1
https://www.foobar2000.org/download
Thanks a lot! Tried 1.6.10 and it works, however, I get a short pause after 6 seconds of playing the streams and sometimes more random pauses after that. This was not an issue before and the streams still work fine using the FFmpeg decoder. Would be great if others could confirm with streams that are not from Swedish Radio since they are the only ones I know that had this problem.
Sorry, but for Danish HLS stations playing just stops after about 5 seconds with 1.6.10 HLS decoding.
Thanks for reporting, investigating.
Improved in beta 2.
Works fine here now, I let a few streams run for at least a minute and no skips. Thanks a lot!
Also works fine here. Thank you
