Topic: Wanted v0.9 plugin ports (Read 748805 times) previous topic - next topic
Reply #150
foo_uie_tabs ??? for what ? try to use layout option in columnsUI
effects are much better ----> http://my-foo.xt.pl
[a href="index.php?act=findpost&pid=376630"][{POST_SNAPBACK}][/a]
okay, and... any info on how to do that?
Reply #151
quicktag SQLite or something similar (stores custom tags into a separate file)
Indispensable to tag tracks while listening to them and  without touching the file itself. (I'm doing it with a remote to tag rating, tempo and situation, then, every now and then I copy these tags to the files in bulk).
Reply #152
patchu - How did you get the (menu item?) buttons across the bottom?
Reply #153
[a href="index.php?act=findpost&pid=378598"][{POST_SNAPBACK}][/a]
It took me a long time to find out what the layout tab is for, but yesterday I played a bit with my settings and finally know how all the guys here do the layout stuff ^^
You can start of with a seperator as base and add sub-panels, think the rest is kind of selfexplaining, at least if you spent some time to find out how everything works
Now Have Fun
Sry for Off-Topic...
Reply #154
[a href="index.php?act=findpost&pid=378660"][{POST_SNAPBACK}][/a]
Yes, foo_quicktag_sql
This one actually delays my moving on to 0.9
Reply #155
QUOTE(patchu @ Mar 29 2006, 01:18 PM)
check this
Reply #156
Now Have Fun
[a href="index.php?act=findpost&pid=378992"][{POST_SNAPBACK}][/a]
WOOT!!! I finally found it too... AWESOME!!! thanks for the indirect tip...
Reply #157
check this
was bit to lazy to make one myself.
Back ² topic:
foo_channel_mixer is ported already ^^
heres the topic: [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=29985" target="_blank"]http://www.hydrogenaudio.org/forums/index....showtopic=29985
version is 0.9.3 preview.
EDIT: argh, wrong quote.. well.. ^^ too lazy to edit...
Reply #158
I thought that foo_playlist_output was a nifty plugin to have, along with foo_playlist_output_custom
Reply #159
why isn't there any kind of (stereo) visualisation (panel) plugin yet?
Reply #163
foo_soundtouch
Reply #164
Can anyone update foo_customsort to work with Foobar 0.9?
For those not familiar with it, it allows you to create multiple sort strings so you can can quickly choose a different order to display your music in.  It adds them to the Sort menu in the main Foobar menu, so its handy to assign them to F-keys to quickly re-sort.
I'm relluctant to move full time to 0.9 until I can get this or something similar.
Reply #165
I'd love to see this plugin too. This functionality could almost be built in...
Reply #166
thank you Seldaek!
maintaining this topic it's just too nice... much better than the "Verified components for foobar2000" topic...
thanks again
Reply #167
The problem is that "Verified components for foobar2000" should be maintained by developers, and obviously they are not ready to do that. I won't blame them, they're already coding all the great stuff. But keeping track of everything on my own is impossible and I'm sure I missed some plugins in my "already ported list". Plus it lacks the last version number/date... Therefore I should work on a better solution by june when I'm done with school, if no-one do it until then.
Reply #168
...keeping track of everything on my own is impossible and I'm sure I missed some plugins in my "already ported list". Plus it lacks the last version number/date... Therefore I should work on a better solution by june when I'm done with school, if no-one do it until then.
About that... see this thread: Central Repository fo Foobar Components
Reply #169
Yep don't worry I keep that link somewhere and I already said there that I would do it if no one else want to. I'd be more than happy to do it in fact as it would motivate me to learn some new language, but right now I can't afford the time.
Reply #170
Damn... for the amount of programming projects I wanna take on, I'm a woefully inadequate programmer.  I need somebody to kick my ass so I start doing some programming again (er... a partner would be nice too).
Reply #171
foo_uie_console
I don't know about anyone else, but I liked it.
Reply #173
Album List panel MODIFIED, to show the cover for the Album List selection if the list has focus
source are with "rexy" album art source
foo_qconfig, usefull to acces quick to dsp manager.
topic and source here:
quick config
Music is my first love.
