Topic: iPod manager (Read 2263822 times) previous topic - next topic
[seemingly abandonware] iPod manager
Reply #2150
Version 0.6.4.9 released. This adds iPhone/iPod touch OS 3.0 support.
Note: You must install both the zlib and updated MobileDeviceSign library to your foobar2000 folder for iPhone/iPod touch OS 3.0 support.
Please report any encountered problems in this thread.
just being curious but how did you address the latest issues with the iTunesDB and SQlite DBs ? I'm also curious to know what the MobileDeviceSign lib is for?
Reply #2152
musicmusic, you are a genius
Just trasfered three albums, all show up with taking my iPod Touch (3.0) anywhere iTunes
Thanks you thank you thanks you
Reply #2153
wohoo i just ordered my iphone 3gs because of the new 3.0 suport. thank you so much
Reply #2154
Yeah, he won't butter his bread with that ^^
Reply #2155
My iPod 2nd gen with 3.0 is not detected. I am using Vista Enterprise.
foo_dop in components and Mobile device and zlib library in \Program Files\foobar2000.
Where else I can look for the reason device is not detected?
V
Reply #2156
oh,  so cool .  how do you do that . I have analysis the CBK file several days. but failed .
can you give some tips?
Reply #2157
In the console, check here:
http://yuo.be/wiki/dop:start#help_my_iphon...is_not_detected
Try #ipodhash on freenode.
Reply #2158
#ipodhash on freenode. ????????????
Reply #2159
#ipodhash on freenode. ????????????  what is freenode?
I am not sure it is appropriate to ask certain problems, while I want to ask that. Since I have studied it for a long time, and i want a tool like foobar2000 on MAC OS X. for the MAC users.  so I want to know the truth. It does not matter if it is inconvenient for you to answer it. Sorry for disturbing you.
Reply #2161
Thanks musicmusic, I should have known better. It works now.
I got this as well:
iPod manager: Error reading Play Counts file : Unsupported file format
ID3v2 parsing failed: Bad unsync
There are 3 files which I get only WXPQ.MP3 and the like. Are those messages related to these files?
V
Reply #2162
musicmusic, just wondering if you could look in to implementing the Autofill feature from iTunes 8.2, would it be possible to get foo_dop to look at how much space is on the connected iPod and just fill it with random music?
Reply #2163
Working great here on my iphone 3GS, thank you.
Reply #2164
Great
This would be my issue. I have put up 0.6.5.0 - it should fix it or otherwise hopefully give a better error. Could you try it and keep an eye out for any similar errors? If you rate a track using your iPod/iPhone, that should be enough to create a new play counts file which foo_dop will then try and read.
This is just from the foobar2000 ID3v2 reader, it means the tag is malformed.
These are files that were added by iTunes. If you don't have any metadata in foobar2000 for them, then yes it could relate to the above.
Reply #2165
I'm not planning to at the moment - sorry, but I added it to the list of requests on the wiki.
Reply #2166
thx musicX2, last version seems to work with my iPhone 3G with 3.0 OS
Regards,
Reply #2167
I get this now with the new dop:
iPod manager: Error reading play counts file: Not a bplist file
Reply #2168
Could you backup the PlayCounts.plist file, in iTunes_Control\iTunes and upload it or send it to me? You might need to do as in my previous post to get a new one to appear. (E-mail addy on my site if you need it.) There are various software around to browse files on iPhone/iPod touches so hopefully you have one/can find one.. Thanks
Reply #2169
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>DBTimestampMasOSDate</key>
<integer>3331409677</integer>
<key>tracks</key>
<array>
<dict>
<key>audioTrackID</key>
<integer>0</integer>
<key>bookmarkTimeInMS</key>
<key>deleted</key>
<false/>
<key>persistentID</key>
<integer>3634666252267980608</integer>
<key>playCount</key>
<key>playMacOSDate</key>
<integer>4294967295</integer>
<key>playedState</key>
<false/>
<key>skipCount</key>
<key>skipMacOSDate</key>
<key>subtitleTrackID</key>
<key>userRating</key>
<integer>100</integer>
</dict>
<dict>
<key>deleted</key>
<false/>
<integer>6339053121830062098</integer>
<true/>
<integer>1</integer>
<integer>3331362025</integer>
</dict>
<dict>
<key>deleted</key>
<false/>
<integer>7003024593816507779</integer>
<true/>
<integer>3331362018</integer>
</dict>
<dict>
<key>deleted</key>
<false/>
<integer>7168905604467952879</integer>
<true/>
<integer>3331361993</integer>
</dict>
</array>
<key>version</key>
</dict>
</plist>
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Added codebox.[/size]
Reply #2170
Doesn't work with my iPod Toucg 2g 3.0.
iPod manager: Listening for Apple mobile devices.
iPod manager: Connected to Apple Mobile Device (DID: 2, PID: 1293, UID: 4ee505e662c58c685acaca96f571bde7f5b3ea02)
iPod manager: USB AMD enumerator: No devices found!
iPod manager: error: Could not locate matching USB device for Apple Mobile Device!
Everything placed in the right folder.
Reply #2171
Thanks. I don't know why they switched from their binary plist format to the XML format but there you go.. (I think it might have been changed somewhere in 2.x actually.) It just means that reading play counts, ratings, deleted files won't work at the moment.
Reply #2172
I was just looking in foobar to assess whether it was working but actually I cannot see the files in the iPod.
Sequence of events from the console:
Send to iPod
Audioscrobbler: Importing played tracks from IPod de Victor
Audioscrobbler: Finished importing 0 tracks.
iPod manager: Generate SQLite database completed in 11.2643155 s
Playback (from foobar)
Opening track for playback: "applemobiledevice://47985c24ee14a12f1d5bbf980b4162205db8a7b3:/iTunes_Control/Music/F50/03 - O.mp3"
I can hear it but it does not appear in my iPod!
Close foobar and open iTunes. I cannot see the file either. (F..k)
Launch Foobar
Location not parsable: "C:\Users\ceakron\Music\iTunes\iTunes Library.itl", reason: Unsupported file format
Audioscrobbler: Handshake successful.
iPod manager: Connected to Apple Mobile Device (DID: 5, PID: 1293, UID: 47985c24ee14a12f1d5bbf980b4162205db8a7b3)
iPod manager: USB AMD enumerator: Found USB\VID_05AC&PID_1293\47985C24EE14A12F1D5BBF980B4162205DB8A7B3
iPod manager: Apple Mobile Device: detected SQLiteDB: true
iPod manager: Apple Mobile Device: detected DBVersion: 4
iPod manager: Got 58 post process SQL commands
iPod manager: Apple iPod/iPhone connected. Device Instance Path: USB\VID_05AC&PID_1293\47985C24EE14A12F1D5BBF980B4162205DB8A7B3
What about this .itl???
Remove from iPod
iPod manager: Generate SQLite database completed in 11.5692359 s
I tried a couple of times. Files do not appear in iPod although foo_dop can read them.
Reply #2173
Must be from the foobar2000 media library folder watcher.
Does foo_dop still see them after opening & closing iTunes?
Can you send me a backup of your iTunes_Control\iTunes folder on your iPod so I can take a look? Thanks.
