When I'm opening a cue sheet file generated with EAC 0.95b3 (non-compliant) I get this error:
opening file for playback - file path: "file://C:\Temp\Everything Falls Apart And More.cue" / index: 0
error opening file for playback (Unsupported format or corrupted file) - file path: "file://C:\Temp\Everything Falls Apart And More.cue" / index: 0
opening file for playback - file path: "silence://1" / index: 0
This is the cue sheet:
REM GENRE Rock
REM DATE 1993
REM DISCID E509ED13
REM COMMENT "ExactAudioCopy v0.95b3"
PERFORMER "Hüsker Dü"
TITLE "Everything Falls Apart And More"
FILE "01 - From The Gut.wav" WAVE
TRACK 01 AUDIO
TITLE "From The Gut"
INDEX 01 00:00:00
TRACK 02 AUDIO
TITLE "Blah, Blah, Blah"
INDEX 00 01:40:45
FILE "02 - Blah, Blah, Blah.wav" WAVE
INDEX 01 00:00:00
TRACK 03 AUDIO
TITLE "Punch Drunk"
INDEX 00 02:09:42
FILE "03 - Punch Drunk.wav" WAVE
INDEX 01 00:00:00
FILE "04 - Bricklayer.wav" WAVE
TRACK 04 AUDIO
TITLE "Bricklayer"
INDEX 01 00:00:00
FILE "05 - Afraid Of Being Wrong.wav" WAVE
TRACK 05 AUDIO
TITLE "Afraid Of Being Wrong"
INDEX 01 00:00:00
TRACK 06 AUDIO
TITLE "Sunshine Superman"
INDEX 00 01:22:55
FILE "06 - Sunshine Superman.wav" WAVE
INDEX 01 00:00:00
FILE "07 - Signals From Above.wav" WAVE
TRACK 07 AUDIO
TITLE "Signals From Above"
INDEX 01 00:00:00
FILE "08 - Everything Falls Apart.wav" WAVE
TRACK 08 AUDIO
TITLE "Everything Falls Apart"
INDEX 01 00:00:00
TRACK 09 AUDIO
TITLE "Wheels"
INDEX 00 02:14:02
FILE "09 - Wheels.wav" WAVE
INDEX 01 00:00:00
FILE "10 - Target.wav" WAVE
TRACK 10 AUDIO
TITLE "Target"
INDEX 01 00:00:00
FILE "11 - Obnoxious.wav" WAVE
TRACK 11 AUDIO
TITLE "Obnoxious"
INDEX 01 00:00:00
FILE "12 - Gravity.wav" WAVE
TRACK 12 AUDIO
TITLE "Gravity"
INDEX 01 00:00:00
TRACK 13 AUDIO
TITLE "In A Free Land"
INDEX 00 02:38:25
FILE "13 - In A Free Land.wav" WAVE
INDEX 01 00:00:00
TRACK 14 AUDIO
TITLE "What Do I Want?"
INDEX 00 02:52:10
FILE "14 - What Do I Want .wav" WAVE
INDEX 01 00:00:00
TRACK 15 AUDIO
TITLE "M. I. C."
INDEX 00 01:13:60
FILE "15 - M. I. C..wav" WAVE
INDEX 01 00:00:00
TRACK 16 AUDIO
TITLE "Statues"
INDEX 00 01:09:17
FILE "16 - Statues.wav" WAVE
INDEX 01 00:00:00
TRACK 17 AUDIO
TITLE "Let's Go Die"
INDEX 00 08:43:06
FILE "17 - Let's Go Die.wav" WAVE
INDEX 01 00:00:00
TRACK 18 AUDIO
TITLE "Amusement"
INDEX 00 01:52:66
FILE "18 - Amusement.wav" WAVE
INDEX 01 00:00:00
TRACK 19 AUDIO
TITLE "Do You Remember?"
INDEX 00 04:54:19
FILE "19 - Do You Remember .wav" WAVE
INDEX 01 00:00:00
I think prior versions of foobar 0.9 worked fine. Using the other cue sheet alternatives EAC has to offer either give me another error (leftout gaps): cuesheet parsing error : unknown cuesheet item
error opening file for playback (Unsupported format or corrupted file) - file path: "file://C:\Temp\Everything Falls Apart And More 4.CUE" / index: 0
or they result in wrong starting points for some tracks (corrected gaps).
Don't tell me this is intentional and a final decision, related to the "fb2k won't accept cue sheets with errors", because it's ridiculous. It makes using fb2k with cue sheets unusable for me.
EDIT: foobar2000 version is 0.9 beta 7...
