Quality (again).
2004-01-30 21:42:39
I know that I`ve asked such question some time ago, but times change, new Fb2k versions come and new hardware too. So I`m starting this topic to generally talk about getting best playback quality possible. At the beggining I`d like to say what configuration do I have: Asus A7V8X-X; AMD Athlon 2500+; 512 Kingston DDR @ 333MHz; SB Audigy 2; Leadtek GF FX 5600 Ultra; Seagate Barracuda ST380011A 80GB; Creative Inspire 6.1 6700. I`ve done some tests using newest beta and last stable version of Foobar on oryginal Creative and kX drivers and that`s what I`ve noticed: - Overall lossy format playback quality seems higher using kX drivers than standard ones on all Fb2k settings. - Resampling doasn`t give so big bost in quality using kX than in Creative. - Hiss level is a lot less noticable using kX than Creative. Ok, now You`ll say - what the hell have kX drivers to Fb2k forums? I`m heading straight to explain: I won`t use kX drivers all over the time cause they don`t use all potential dreaming in Audigy 2 board, so I`m standing with Creative software and I`m asking all of You experienced people about Fb2k optimal settings. I use 24Bit streaming without dightering on Kernell Streaming with DSP settings as follows: Resampler - 96KHz Soft clipping limiter Advenced limiter Gap killer Skip silence Crossfader It makes processor ussage at approx. level of 22% (2500+ @ 1833MHz). What`s weird, when I switch slow mode on resampler, processor usage level doasn`t grow above 22% (also difference isn`t noticable too). What do You think about dightering, should I use it or not, and what about my DSP settins, are they correct in order, or meaby I forgot/added too much to it? I`m waiting for Your opinion.
