Topic: [bug report] foobar2000 v1.6.6 show unicode text as garbled mess (Read 218 times) previous topic - next topic
Specifically if the song contains Japanese character and stored in .zip file, as this is not a problem if the song is not stored in .zip file, v1.6.6 also contain another regression, which, compared to v1.3.6, shows that %directoryname% track grouping is titled '?' for song that stored in .zip file, unlike v1.3.6 when it still correctly show the folder name (or the .zip filename in which the song contained) (shown as BLUNTSIDE - 若いジー.zip)
Re: [bug report] foobar2000 v1.6.6 show unicode text as garbled mess
Cool, not-Unicode ZIP files. Because ZIP never had a standard file name encoding format, although most settle on UTF-8 now, these appear to be Shift-JIS.
When I inspect the zip files using 7z.exe command line, it appears that the filename is already encoded in UTF-8. The garbled text might be the result of foo_unpack decode the UTF-8 text using ANSI encoding:
ANSI: BLUNTSIDE - 若いジー - 01 イントロ.ogg
UTF-8: BLUNTSIDE - 若いジー - 01 イントロ.ogg
You can watch this video for proof of conversion between ANSI and UTF-8 encoding. https://www.youtube.com/watch?v=ViK3eIg_mb4
Fixed for the next update, thanks for reporting.
Indeed ZIP UTF-8 was not recognized.
Edit: Fixed in 1.6.7 beta 6
