This is a BRILLIANT piece of work. Thank you. Can you tell me if it is possible to alter the configuations of the following layouts?:
'Playlist': replace %album% with [%album%]
'Library' replace %artist% with [$stripprefix(%artist%,the)]
'Details': remove Added, Last Played, Count etc, and add [%comment%]
Hi handleyman,
For Playlist try right click on the playlist:
Grouping -> Manage presets
Sort -> by...
For Library, in Panel_Library.js -> var view_ppt = [ , replace View 01 with:
window.GetProperty(prefix + "View 01: Name // Pattern", "View by Artist // [$stripprefix(%artist%,the)]|%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%"),
For Details, in Defaults.js -> const defaultMetadataGrid = [ , section remove want you don't want and add:
{ label: 'Comment', val: '[%comment%]' }
After that delete your georgia-config.jsonc ( after the new release it will be georgia-reborn-config.jsonc ) and go to top menu
Options -> Developer settings -> Disable right-click ( should be off )
Now on the top menu right click -> Panel properties and hit Clear and reload/restart the theme.
Btw, I would not do it right know because I will release a BIG important update which I have worked for the last
3 weeks and the file structure is changing, so you would need to do a new clean installation anyways...
-TT
