Topic: Normalization before encoding (Read 3277 times) previous topic - next topic
this post could be in any lossy codec thread, vorbis isn't the matter.
I also don't want to speak about vorbisgain or mp3gain it's not the topic today
hypothesis 1) taken a 16-bit wave which is, from the start, perfectly scaled. I mean that signal reach inferior and superior boundaries of 16 bit signed integer at least once on the track whithout clipping.
The coder have the sharpest defined signal as input and so offer the best during the compression * ?... true or false
hypothesis 2) taken a 16bit wave which could be normalized by a factor 175 / 172. (each sample are divided by 172 and multiplied by 175 in float and then converted to integer)
This big ratio followed by an integer rounding distord the signal ?... true or false or not noticeably
So if I normalize I can use most of the possibilty of the coder but I could also alter the sound ...
What do you think about it ?
(And I don't ask your opinion about my awfull english, for this please complain to Miss *biiip* english teacher at *censured* high school )
* I have read some dumb posts where smart people noticed that when they reduced the volume by two before the encoding they get better compression ratio... but they forget that the quality was also twice lower. Almost a 8-bit wave ^^
how do do conclude that ?, lower volume doesn`t mean lower quality.
The first case would be ideal, provided that no normalization or volume changes happened _beforehand_ to get such a 'perfect' signal.
I'm not sure what you mean with the second one. If I assume that you'd have to do the operation you describe to get a wave like (1), then yes, there will be a minimal and inaudible quality loss. But there is no point in doing this 'just' to get a signal as in (1). You can't 'add' information that isn't there by normalizing the wave.
Also both waves could _still_ clip after encoding, which is why normalizing as a whole is pointless.
The "dumb" one here is you. Reducing the volume by 2 will lose 1 bit of precision, leaving you with a 15 bit wave. The loss of quality is inaudible in normal circumstances.
haha it's true I go back to my calculator to find the LOG key... sorry for that
hopefully I've studied math better than english.
/me slap himself with a bunch of thorns
