Topic: SqrSoft Advanced Crossfading (Read 2932 times) previous topic - next topic
This DSP allows you to smart-crossfade 2 tracks.
The main features are:
  • Automatic detection of begin/end mixing cues, that can be set according to the desired sound level (in dB).
  • Maximum analysis time can be set to limit the detection range (or to use less resources).
  • Custom fade-in/out time, initial level and curve (< 1: logarithmic, > 1: exponential).
Download link here.
Hope you enjoy it! :)
Re: SqrSoft Advanced Crossfading
Download link here.
Very good! I liked.
wagner reatto
Download link here.
.I just open the HA page a then i get the the shock.
Developer of the famous SQR plugins like compressor and advanced crossfader
came to HA and develop advanced crossfader for F2K like in winamp.
If you going to search in this forum, you can find this request more than one time to
create this plugin for F2K.
So everything is possible.
Thank you very much for plugin.
Would you please add manual and preset option to handle and open, and save winamp APF* settings?
Would you please can create SQR compessor plugin for F2k for this setup? http://www.braingell.com/djtools/SQRSoftSetup.htm
http://www.braingell.com/djtools/djtools.htm
Sure, I will add manual pages to the wiki soon.
This component is a complete rewrite, a very basic version of my old Winamp plugin. I could add preset import/export options if you need them, just tell me what other functions you miss from the old one (I know, you're gonna say ALL 8)) and them will be added to the next releases.
The compressor/limiter component was ported to foobar2k a long time ago, I'll add it to the 3er party components page ASAP.
Thank you very much.
Mariano,
Thank you for creating this.  I have been using your crossfading plug-in for Winamp for over 20 years because it's the best crossfading plugin out there.
I was wondering if you were planning to release this plugin for Foobar Mobile, IOS?
Your dynamic algorithm makes huge difference when it comes to the correct time to begin the cross fade process.
I would love to hear from you again.  I've reached out to you via e-mail a few times recently, but you may not have seen them.
Thanks,
Allen...
Hi, i have a problem with this crossfader. On foobar2000 1.6.11 fade-out didn't work, only fade-in. Stock crossfader works normal.
Laptop onboard Realtek sound chip
Buffer set to 12100ms
DSP: Resampler (to 44100kHz) and then the Sqr crossfader
