Topic: menu_item.h API (Read 3278 times) previous topic - next topic
menu_item.h API
an
bool is_enabled();
method on the menu items would be useful to allow items to be turned on/off based on other state information in the player or component.
Can you add a separator programmatically from the menu_item interface?
ie. from
virtual const char * enum_item(int n)
menu_item.h API
Already implemented as the return value for get_display_data().
menu_item.h API
Sorry, I don't see how I use that to disable (MF_GRAYED style) one of my menu items.
For is_checked() I get a chance for each item in my menu instance to set or not set the check mark.  I'd like the same thing for enabling or disabling the item.
menu_item.h API
Maybe you can override
virtual enabled_state get_enabled_state(int idx)
and return MENU_DEFAULT_OFF when you don't want to display a specific menu item (but yes I know - that's not MF_GRAYED).
~ Florian
menu_item.h API
~ Florian
Damn, I totally overlooked that as I was looking down in the derived object's interface.
menu_item.h API
So, the last question remains,
Is there a way to add separators in
 return NULL;
