Hi to all,
I have a little question about the setting of XLD when we use it for codify an MP3 from a FLAC file.
I have see that it use the LAME codec and I can chose if use Joint Stereo or Stereo.
What do you suggest for the best result?
I suggest that you search.
Funnily enough, I seem to recall this suggestion having been made to you many times before.
First: use the default.
Second: if forced to choose, choose joint stereo (which is the default).
Lame Mp3 settings in XLD should look like this,
Encoding Mode: VBR (recommended)
Overall Quality: Default (-q 3)
Stereo Mode: Auto (recommended)
Sampling Frequency: Auto
VBR method: New (faster)
Target Quality (LOWER is BETTER): << This is up to you to decide.
