Topic: Georgia: A dynamically generated fb2k theme (Read 96660 times) previous topic - next topic
Re: Georgia: A dynamically generated fb2k theme
Reply #300
Since Georgia 2.0.0 the Spider Monkey Panel is required instead of the JScript Panel.
See the detailed Georgia installation instructions here.
Reply #301
Version 2.0.3 released.
Also added a video to explain some of the new cdArt options/settings:
https://www.youtube.com/watch?v=_jplUBlRNos
Reply #302
 How to only use the embedded album art ? I try the cdArt setting to but cant seem to work. My folder usually contain many images, I dont want to delete all of them.
Reply #303
 Nevermind, found the setting in .json file.
 Sorry for double post cuz I cant delete it  :'(
Reply #304
All good. I'm working on something that will hopefully improve the discoverability of some of these settings/features, but we'll see if it makes it off the ground.
Reply #305
@MordredKLB Can I change the upper font to look like the one at lower side ? The upper one is not looking good in my language.
X
Reply #306
If you look closely the bottom one also does not look correct. Those characters just aren't available in the font so it's falling back to a thicker font that does contain them.
Fortunately this can be changed fairly easily. First let's change lines 94-96 to a font that will hopefully work better than either:
	ft.title_lrg = font(fontLightAlternate, 34, 0);
ft.title_med = font(fontLightAlternate, 30, 0);
ft.title_sml = font(fontLightAlternate, 26, 0);
If that still doesn't improve things, change them to this which is the font currently being used on the bottom.
	ft.title_lrg = font(fontLight, 34, 0);
ft.title_med = font(fontLight, 30, 0);
ft.title_sml = font(fontLight, 26, 0);
Reply #307
This solution work, not perfect but I'm happy as it is. Thanks you very much ;) .
PS: It's done so pls ignore my PM  :D
Reply #308
Hello, this is my first post on this forum, so apologies if I am breaking any rule.
Is there any way to remove the big pause icon located at the center of the album cover? I don't want it to show while the song is paused, I want to see that artwork clearly during the pause.
Reply #309
It doesn't look like it's optional so as a workaround for now, you can browse the Georgia folder and browse inside js and open ui-components.js in a text editor.
On line 21, there is a function that starts with
    draw(gr) {
Insert this as the first line after it...
return;
Reply #310
Thank you. Definitely needs to be added as an option.
Reply #311
Sorry to necrobump, but has anybody figured out how to get this looking nice on Linux? I was close with adding gdiplus to my wine prefix but now I can't get it to recognize any of the fonts
Reply #312
Hello Georgia users, this thread has been quiet, but hopefully I'm not the only one of us that's still here.
I've been having this recurring issue where it tends to throw an error on startup/restart. As soon as I reload everything is fine:
foo_spider_monkey_panel:
Error: Spider Monkey Panel v1.6.1 ({2145C8FF-E749-4BAA-BF12-D520F28D0E15}: Georgia v2.0.3 by Mordred)
setInterval failed:
`delay` must be non-zero
File: georgia-main.js
Line: 2104, Column: 22
Stack trace:
  on_playback_pause@georgia-main.js:2104:22
It's been happening for quite a while, but since it usually disappears I didn't bother reporting it until now. Not entirely sure if this was caused by something like a component upgrade. I've been upgrading non-beta components as updates get released.
I've also noticed this strange behavior where all of my lyrics seem to be alphabetically sorted before being displayed, resulting in them appearing in a completely nonsensical order. Looks like I've got OpenLyrics 1.4 installed since that seemed to be the most recommended current lyrics module. Use of others seemed to be actively discouraged due to inefficiencies/bugs/etc.
Reply #313
What file types are you seeing this in? Also is it local or something you're streaming over the internet? Is the file already playing when Georgia loads?
Regardless if you pull down master it should now have a fix to prevent this from ever happening:
This could be caused by unsynced lyrics that it thinks are synced for some reason. Could you send me a lyric file this is happening with? Should be an easy fix.
Reply #314
It was occurring with FLACs located on a local Synology NAS connected via SMB.
Replaced 2.0.3 with github master and the problem went away. Thanks!
Doh. I can't remember which songs I was listening to the other day that reproduced this and now all of the ones I'm picking are working. I'll let you know if I find it again.
Reply #315
Stumbled across a different problem. Almost all of my library has been tagged using MusicBrainz Picard, so I have metadata in the following fields:
Date
<ORIGINALDATE>
<ORIGINALYEAR>
The displayed titles in the library view appear correct, but the sort is not. The display appears to be using one of:
<ORIGINALDATE>
<ORIGINALYEAR>
but the sort appears to be using:
Date
I glanced at the code and it appears to be correct:
https://github.com/kbuffington/Georgia/blob/15b90f5a399c0a37ca15da2ce0d8b0094861423d/js/CaTRoX_QWR/Panel_Library.js#L787-L788
Any ideas?
Reply #316
<ORIGINALDATE>
<ORIGINALYEAR>
Date
In your georgia-config-xxx.jsonc file change this line:
"defaultSortString": "$if2(%artist sort order%,%album artist%) $if3(%album sort order%,%original release date%,%date%) %album% %edition% %codec% %discnumber% %tracknumber%", // Default sort playlists generated from Library selections or clicking on playlist Hyperlinks
to this and let me know if that fixes the problem:
"defaultSortString": "$if2(%artist sort order%,%album artist%) $if3(%album sort order%,%original release date%,%originaldate%,%originalyear%,%date%) %album% %edition% %codec% %discnumber% %tracknumber%", // Default sort playlists generated from Library selections or clicking on playlist Hyperlinks
Reply #317
So I was able to reproduce this behavior. Strangely I have no lyrics file saved. After looking at a few entries in an OpenLyrics search, I'm pretty sure this is the one being automatically used based on some of the partial lyric snippets. It appears to be coming from genius.com and shows up in my tool as unsynced (no timestamps).
Spoiler (click to show/hide)
Reply #318
<ORIGINALDATE>
<ORIGINALYEAR>
Date
That did the trick, thanks.
