Topic: How to convert WAV to FLAC conversion via batch script? (Read 8654 times) previous topic - next topic
I'm interested in creating a batch script that will help convert multiple WAV files to FLAC files, and numerous searches in this forum only shows solutions that aren't compatible with Windows 8.
BTW: Yeah, I know I can use fb2k. But I'm interested in doing it the old school way.
ghostman
flac *.wav
see https://xiph.org/flac/documentation_tools_flac.html#usage, though I'm not really sure if FLAC handles that correctly when using CMD, since with CMD wildcard expansion has to be performed by the program itself. Powershell does wildcard expansion, though.
So, in CMD your best bet would be:
FOR %%F IN (*.wav) DO flac %%F
see http://ss64.com/nt/for.html. Use only one % when invoking from the CMD shell directly, and two %% in batch scripts.
Don't you need a /R switch and - at least for typical file names these days - enclose "%%F" in quotation marks?
Not to mention that oldschoolness requires you to read yourself up on all switches like whether to keep foreign metadata, verification, logging of errors, ...
flac *.wav
I ended up choosing the 2nd option, but it didn't work at all. Put that line into a TXT file, renamed the extension BAT, put flac.exe, metaflac.exe and a wav file into a folder with it. But whether I dragged the WAV file onto the BAT file or just clicked on it, nothing worked.
ghostman
:loop
if %1.==. goto end
flac %1
shift
goto loop
:end
Okay, this script successfully worked. I'm curious, though, how to modify it to use pipe encoding, if it doesn't already.
ghostman
please explain.
Does the script use temp wav or pipe encoding? I've heard that the latter is more efficient.
ghostman
Flac reads directly from a wav file and writes directly to a flac file, There are no intermediate files.
Great. That's good to know.
ghostman
So now that the basics are locked down, I was wondering how the batch script could be modified so that the end product ends up in a separate folder (i.e. like it does in SoX)
ghostman
Funny ;-)
But, seriously, didn't Synthetic Soul have a script that could direct output to a specific folder?
ghostman
