Topic: Joining 24bit/96kHz wave files (Read 3897 times) previous topic - next topic
I would like to proper join 24bit/96kHz wave files with WAVE_FORMAT_EXTENSIBLE (DVD-A explorer). Foobar2000 join, but result is standard wav PCM without WAVE_FORMAT_EXTENSIBLE. Anyone could help ?
WaveWizard can be used to append several wave files (amongst other operations).
Go to Preferences and choose Stream manipulation -> "Stitch files". Carefully go through the other options to make sure you don't perform other unwanted operations, like dither and normalization.
@j7n: Working also with multichannel wavs  Thank you.
I tried encode multichannel wav stitched and flac report this error:
track-01-01[1]-01-[Lf-Rf-C-LFE-Ls-Rs]-24-88200_Stitch.wav: ERROR: WAVEFORMATEXTENSIBLE chunk with unsupported channel mask=0x0000
separate wavs are encoded fine....
The channel mask=0x0000 indicates that none of the channels have been assigned to speaker "positions". There is a FLAC command line parameter to ignore the channel mask, but I forget what it is for the moment (I did find it recently when I encoded the Microsoft 8_Channel_ID sample).
Multichannel wavs are bad stitched because every wav before stitched has 0x003F mask inside.
This program indeed does not write the channel mask. I used a hex editor to quickly add these one or two bytes.
It does not make this program useless. Consider that the alternative is to use an audio editor. In that case there'd be a considerable overhead in required disk space for temp files. A space which you might not have while working with overly huge DVD-A files.
I'm using as outputformat Wave PCM, and foobar to encode it to flac.
.halverhahn
