DRM Issues -- with my own music
Reply #12 – 2005-01-31 14:35:38
even with MD recorders, Sharp are known to make a better one. Be careful. In Germany we have an idependent test magazine (no advertisement), founded by a former government; they didn't rank sharp generally better than Sony. Also sharp only (or mostly) produces MD-portables, no standalone recorders...back on topic: did the TOC hacking work? if the only way to get the data off is through USB or optical in realtime, then by all means do that. get the stuff onto CDs as soon as possible, then you're free to do what you like. [a href="index.php?act=findpost&pid=269576"][{POST_SNAPBACK}][/a] It works! A thing I think I should explain here: The SCMS system consists of two steps: -the general copy bit = "this audio is protected by copyright law" It is automatically set when an audio recorder (home or portable) records from an analogue source. It can be disabled when burning audio CDs and when using a soundcard's digital output. It is alway set on factory-pressed CDs. -the additional copy bit = "this audio has already been copied digitally" If set on an audio recorder's digital input, it prevents the recording. It is automatically set during recording if the "general copy bit" is set. If this isn't the case, then the according audio is considered free material and can be recorded again and again, an infinite number of generation copies is possible, as long as all copies are digital.What's funny is that manufacturers such as Sony claim SCMS as a product feature, i.e. something that you as a consumer would want. Get your bowl of acronym soup. [a href="index.php?act=findpost&pid=269578"][{POST_SNAPBACK}][/a] Indeed; in Sony style the say. "You can be sure that you always have the best quality, because you have the original." (SACD marketing trick)
