Topic: show correct *.m4a bitrates with WinAmp 5 (Read 1732 times) previous topic - next topic
I noticed WinAmp 5 (at least) shows the correct bitrate of the iTune encoded files. The funny thing is: Dare to change the id-tag with WinAmp 5 and the correct bitrate is shown in iTunes. But ... you can't play the file any longer with iTunes. If you erase the discnumber added by WinAmp 5 with foobar the files are playable with iTunes again!!!! Now with the correct bitrate. You will notice that the newer encoder (since 4.5) produces half VBR-files. Encoding ambient music (for instance) show an average birate of 115 kbs instead of the 127-129 from older encoder versions.
I never had problems with artifacts at this bitrate ...
In my opinion the sound quality significantly increased especially at 128 kbs.
