Topic: Parens, square brackets, or curly brackets in album names. (Read 1072 times) previous topic - next topic
Hello, I've noticed that some people use parens, square brackets, or curly braces when adding additional information to the albums. I created a forum thread a couple of months ago and the user "porcus" suggested using the curly braces because they are more unique  and less likely to appear in album names.  https://hydrogenaud.io/index.php/topic,121582.msg1003479.html#msg1003479
I don't care if square brackets appear in the actual album name because I can remove those if needed.  There are not so many albums with square brackets in them anyway.
The thing I'm curious about if the information in square or parens are picked up by any media playing software? I don't want the media playing software to read the information out of the square brackets. I guess that's not a problem with curly braces.
       - 1976 _ Album [1978 US ~ Columbia ~ CK 23434]
Do you know if any software reads out the information from [] or ()? I don't want that.
Re: Parens, square brackets, or curly brackets in album names.
If these are folder names and your media playing software is using the tags then you'll be fine. If you've stored all this information in your album tag then you'll likely see it in your player too - unless you can customise it, and strip it all out like you can in foobar.
