Topic: Unable to open/convert mini2sf files. (Read 1365 times) previous topic - next topic
Hi all. This is probably a matter kode54 can answer.
I've been trying to decode some mini2sf files so that I may play them with other music players or devices. These files originate from Zophar's site and I'm using the 2SF decoder (foo_input_vio2sf; version 0.26.2). However, when I try to open or convert them, I get:
Unable to open item for playback (Unable to open 2SF file):
"C:\105 COUNT DOWN.mini2sf"
or
1 out of 1 files converted with major problems.
Source: "C:\105 COUNT DOWN.mini2sf"
  Unable to open source file: Unable to open 2SF file
  Conversion failed: Unable to open 2SF file
I'm fairly new; is there a step that I may have missed? Is there a better approach to doing what's been described?
Re: Unable to open/convert mini2sf files.
There must be file with extension 2sflib in the same folder where *.mini2sf files are located. When you download all tracks in one archive, 2sflib is there.
I followed your suggestion and the issue was promptly solved.
