Topic: Grouping convert presets (Read 631 times) previous topic - next topic
As you can see in the image I have a very long list of custom convertion presets: is it possible to make foobar2000 able to group presets in custom groups?
Re: Grouping convert presets
That sounds like it'd be a good idea, and this also seems like a good place to mention a minor converter configuration annoyance (or two).
It'd be great if the size of the columns displaying the encoder name and settings under "Output Format" would "stick", or at least auto-size so it's possible to read all the text. Currently the columns have to be resized manually each time "Output Format" is opened.
When "Output Format" is opened.
This would be better.
When opening the Converter setup, the Saved Presets list on the left is contained in a "frame" of a fixed size. It'd be nice if it could be resized to eliminate the need for scrolling. Currently the only way to achieve that is to resize the entire "window" which can use a lot of screen real estate.
Having to scroll or use the tooltip to read all the text.
The whole window has to be resized to show all the text on the left.
