I have a problem with profiles to use. I did setup profile for DreamBox, and every time I start to play upnp selects Default profile. I can see at logs, it selects DreamBox profile, but apply Default profile for track. Why?
User-Agent: Dream Multimedia Dreambox Enigma2 Mediaplayer
foo_upnp: 158.158667: RendererController::GetNearestResource(188)/4960: INFO: matching resource url to target ip 192.168.0.10: [url="http://192.168.0.19:56923/content/3941e5a8dae09cabecf8d3f56dac96e9.wav?profile_id=0&convert=wav"]http://192.168.0.19:56923/content/3941e5a8...amp;convert=wav[/url]
foo_upnp: 158.158822: upnp_server_conf::get_profile(937)/2448: INFO: using profile 'DreamBox', matching header (User-Agent:Dream Multimedia Dreambox Enigma2 Mediaplayer)
foo_upnp: opened 'file://\\diskstation\music\#Chillout\6th Sense - Sleepless (BVCP-21321) - FLAC\08 - Keep On Walking.flac' for streaming, profile: Default, WAV / 44100 Hz / 16 bits / 2 channels, replaygain: off, DSP chain: off
foo_upnp: 158.158991: controller_window::set_track_info_string(1112)/4960: INFO: track info display: 6th Sense - By My Side | PCM | 1411 kbps | 44100 Hz
foo_upnp: 159.159410: controller_window::set_track_info_string(1112)/4960: INFO: track info display: 6th Sense - Keep On Walking | PCM | 1411 kbps | 44100 Hz
foo_upnp: 160.160466: controller_window::set_track_info_string(1112)/4960: INFO: track info display: 6th Sense - Keep On Walking | PCM | 1411 kbps | 44100 Hz
foo_upnp: 161.161281: UPnPAVRendererController::set_transport_state(232)/4960: INFO: No local playing item
foo_upnp: 161.161282: controller_window::set_track_info_string(1112)/4960: INFO: track info display: Stopped
