Topic: Monkey's Audio --> MPC (Read 3595 times) previous topic - next topic
Hi! I want to convert a few Ape files to mpc with the Monkey's Audio GUI. I've copied the mppenc.exe (1.14) into the "external" path of the Monkey's Audio directory.
The commandline in Monkey's Audio for mppenc.exe is --quality 6 --xlevel
but after decompressing the ape file, it stops and says "error: undefined"
what's wrong with my settings??
FLAC and MPC supporter - but a nOOb
Christian.Denk2 at web dot de
About a half your ago the construction (syntax) of the MPC command line changed. The Monkey's Audio frontend doesn't work with the newer MPC encoders. But you can use MPC Batch Encoder for this if you like.
