Topic: [crashware] foo_popupplus (Read 495824 times) previous topic - next topic
Reply #50
Hi thanks for your help
my cover is named cover.jpg and is in the same folder as the mp3 file but no cover appear in the popup.
Reply #51
May you add option to show popup on pause/unpause?
Reply #52
I'm planing to add an option to choose on which events will popup appear.
and skin you use is ??? because for me it works with every skin where avatar is enabled
Reply #53
Modernplus is the skin that I use
Reply #55
I think you'd better change the "Enable avatars" sentense to "Enable album art" or something like that to avoid confusion. This isn't a computer game.
Reply #56
This depends on popup skin, do not forget that all skins placed at foo_popupplus directory were created for IM client.
for example in Popup Classic skin see this part of code in PopupClassic.popupskin file
options
    #option    id    val    title
    option    1    1    Draw gradient background
    option    2    1    Flat borders
    option    3    1    Enable avatars
end
where id is option identifier, val is initial option value and title is shown in Skin options
Reply #57
I have to report a bug : I have noticed a memory leak when using foo_popupplus, that keeps raising on every song change till I close foobar.
For information, I use the release 20070805 of popupplus and foobar v9.4.3, on win xp sp2.
It seems that this issue is caused by the handling of album art images, even when the skin doesn't include album art display.
Using large size images, memory usage increases dramatically, it seems that the plugin keeps all images uncompressed in ram.
Really nice plugin however, that could finally replace foo_toaster. Thanks for you work adamh.
Reply #58
Yes you are right, I will look at it.
Now the problem was solved in new build (20070806)
Reply #59
Wow ! You're faster than lightening. It works fine now.
Thanks again.
Reply #60
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0198E632h
Access violation, operation: write, address: 006C0071h
Call path:
Code bytes (0198E632h):
0198E5F2h:  04 00 CC CC CC CC CC CC CC CC CC CC CC CC 8B 46
0198E602h:  10 57 33 FF 3B C7 74 09 50 E8 8C A3 01 00 83 C4
0198E612h:  04 8B 06 8B 4E 08 50 51 FF 15 80 B0 9A 01 50 FF
0198E622h:  15 7C B0 9A 01 8B 56 08 52 FF 15 70 B0 9A 01 56
0198E632h:  89 7E 08 89 7E 04 89 7E 0C 89 7E 18 89 7E 14 E8
0198E642h:  5C A3 01 00 83 C4 04 8B C6 5F C3 CC CC CC 56 57
0198E652h:  8B F8 A1 FC 89 9B 01 57 50 6A 00 6A 00 68 00 00
0198E662h:  00 80 68 00 00 00 80 68 00 00 00 80 68 00 00 00
Stack (0528FB70h):
0528FB50h:  00000000 00000000 00000000 00000000
0528FB60h:  00000000 00000000 00000000 00000000
0528FB70h:  006C0069 01E97810 0198E570 B978CD15
0528FB80h:  00000002 01E97810 00000000 0528FCB0
0528FB90h:  019A982B 00000000 0198F341 01E97810
0528FBA0h:  01E97810 00D7E0B8 0528FBC4 778924AF
0528FBB0h:  00D7E0B8 FFFFFFEB 00000000 00000002
0528FBC0h:  00000002 0528FC00 77892539 00D7E0B8
0528FBD0h:  FFFFFFEB 77892545 B96CCA85 00000002
0528FBE0h:  00000002 00150312 0528FBD8 77892937
0528FBF0h:  0528FCB0 778D76CC CBCD13CD B978CD31
0528FC00h:  77892545 00000000 0198F65F 00000000
0528FC10h:  0528FC98 00000002 0528FC48 00000000
0528FC20h:  77891A10 00150312 00000002 00000000
0528FC30h:  00000000 00000002 DCBAABCD 00000000
0528FC40h:  0528FC98 00000002 0528FCC0 77891AE8
0528FC50h:  0198F620 00150312 00000002 00000000
0528FC60h:  00000000 B96CCA45 00000000 00150312
0528FC70h:  0008CFEB 00000024 00000001 00000000
0528FC80h:  00000000 00000030 FFFFFFFF FFFFFFFF
Registers:
EAX: 00000000, EBX: 73054B72, ECX: 00C02770, EDX: 49C70277
ESI: 006C0069, EDI: 00000000, EBP: 0528FC04, ESP: 0528FB70
Crash location: "foo_popupplus", loaded at 01980000h - 019C8000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 77D80000h - 77E9E000h
kernel32                        loaded at 77660000h - 77738000h
COMCTL32                        loaded at 753D0000h - 75564000h
msvcrt                          loaded at 76740000h - 767EA000h
ADVAPI32                        loaded at 779E0000h - 77A9F000h
RPCRT4                          loaded at 77910000h - 779D3000h
GDI32                            loaded at 767F0000h - 7683B000h
USER32                          loaded at 77870000h - 7790E000h
SHLWAPI                          loaded at 77F60000h - 77FB5000h
SHELL32                          loaded at 76970000h - 7743E000h
ole32                            loaded at 77AA0000h - 77BE4000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 775D0000h - 77644000h
IMM32                            loaded at 76720000h - 7673E000h
MSCTF                            loaded at 768A0000h - 76967000h
LPK                              loaded at 76840000h - 76849000h
USP10                            loaded at 77EA0000h - 77F1D000h
uxtheme                          loaded at 756D0000h - 7570F000h
foo_abx                          loaded at 011D0000h - 01203000h
foo_albumlist                    loaded at 01240000h - 01287000h
OLEAUT32                        loaded at 76690000h - 7671C000h
foo_audioscrobbler              loaded at 012F0000h - 01327000h
WS2_32                          loaded at 77F30000h - 77F5D000h
NSI                              loaded at 77650000h - 77656000h
foo_burninate                    loaded at 01330000h - 01367000h
VERSION                          loaded at 75D40000h - 75D48000h
foo_cdda                        loaded at 01370000h - 013A5000h
foo_converter                    loaded at 013B0000h - 01419000h
foo_cwb_hooks                    loaded at 01430000h - 01465000h
foo_dsp_std                      loaded at 015D0000h - 01611000h
foo_freedb2                      loaded at 01650000h - 01690000h
foo_input_std                    loaded at 01810000h - 01923000h
foo_masstag                      loaded at 017A0000h - 017EF000h
foo_playcount                    loaded at 01930000h - 01958000h
foo_popupplus                    loaded at 01980000h - 019C8000h
RICHED20                        loaded at 71780000h - 717F4000h
gdiplus                          loaded at 74E80000h - 7502A000h
MSVCP80                          loaded at 72250000h - 722D7000h
MSVCR80                          loaded at 73050000h - 730EB000h
foo_rgscan                      loaded at 01A10000h - 01A58000h
foo_scheduler                    loaded at 01C00000h - 01C6F000h
POWRPROF                        loaded at 75980000h - 7599A000h
WINMM                            loaded at 749B0000h - 749E3000h
OLEACC                          loaded at 74970000h - 749A8000h
foo_uie_albumlist                loaded at 01A90000h - 01ACD000h
foo_uie_quicksearch              loaded at 01C70000h - 01CB6000h
foo_ui_columns                  loaded at 01FB0000h - 02047000h
foo_ui_panels                    loaded at 02220000h - 02309000h
foo_ui_std                      loaded at 01D40000h - 01D97000h
foo_unpack                      loaded at 01D00000h - 01D2E000h
Msimg32                          loaded at 75C30000h - 75C35000h
dwmapi                          loaded at 73930000h - 7393C000h
DSOUND                          loaded at 71FB0000h - 72021000h
CLBCatQ                          loaded at 77470000h - 774F4000h
MMDevApi                        loaded at 756A0000h - 756C7000h
SETUPAPI                        loaded at 77BF0000h - 77D78000h
WINTRUST                        loaded at 757D0000h - 757FD000h
CRYPT32                          loaded at 76030000h - 76121000h
MSASN1                          loaded at 76170000h - 76182000h
USERENV                          loaded at 764F0000h - 7650E000h
Secur32                          loaded at 764D0000h - 764E4000h
imagehlp                        loaded at 77440000h - 77469000h
audioses                        loaded at 74770000h - 74791000h
audioeng                        loaded at 74700000h - 74766000h
AVRT                            loaded at 75960000h - 75967000h
PSAPI                            loaded at 765A0000h - 765A7000h
SXS                              loaded at 763B0000h - 7640F000h
dbghelp                          loaded at 71650000h - 7172C000h
Stack dump analysis:
Address: 0198E570h, location: "foo_popupplus", loaded at 01980000h - 019C8000h
Address: 019A982Bh, location: "foo_popupplus", loaded at 01980000h - 019C8000h
Symbol: "foobar2000_get_interface" (+00002ADBh)
Address: 0198F341h, location: "foo_popupplus", loaded at 01980000h - 019C8000h
Address: 778924AFh, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "SetWindowLongW" (+00000065h)
Address: 77892539h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77892545h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "GetWindowLongW" (+00000037h)
Address: 77892937h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "IsWindow" (+0000003Dh)
Address: 778D76CCh, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "AlignRects" (+00001926h)
Address: 0198F65Fh, location: "foo_popupplus", loaded at 01980000h - 019C8000h
Address: 77891A10h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "GetMessageW" (+0000006Eh)
Address: 77891AE8h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "GetMessageW" (+00000146h)
Address: 0198F620h, location: "foo_popupplus", loaded at 01980000h - 019C8000h
Address: 77891A91h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "GetMessageW" (+000000EFh)
Address: 77891C03h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "GetMessageW" (+00000261h)
Address: 77893656h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "OffsetRect" (+0000004Dh)
Address: 77DE0E6Eh, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "KiUserCallbackDispatcher" (+0000002Eh)
Address: 77DE0E20h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "KiUserApcDispatcher" (+00000048h)
Address: 77891BB8h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "GetMessageW" (+00000216h)
Address: 77888C3Ah, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "DestroyWindow" (+0000000Ch)
Address: 0198EDFAh, location: "foo_popupplus", loaded at 01980000h - 019C8000h
Address: 0198F378h, location: "foo_popupplus", loaded at 01980000h - 019C8000h
Address: 77892A47h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "IsWindow" (+0000014Dh)
Address: 77892AA1h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "TranslateMessage" (+00000000h)
Address: 778919A2h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "GetMessageW" (+00000000h)
Address: 77892A89h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "DispatchMessageW" (+00000000h)
Address: 77892A98h, location: "USER32", loaded at 77870000h - 7790E000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0198F6DEh, location: "foo_popupplus", loaded at 01980000h - 019C8000h
Address: 73052848h, location: "MSVCR80", loaded at 73050000h - 730EB000h
Symbol: "endthread" (+0000004Bh)
Address: 73058B7Dh, location: "MSVCR80", loaded at 73050000h - 730EB000h
Symbol: "_dllonexit" (+0000009Dh)
Address: 730528C8h, location: "MSVCR80", loaded at 73050000h - 730EB000h
Symbol: "endthread" (+000000CBh)
Address: 776A3833h, location: "kernel32", loaded at 77660000h - 77738000h
Symbol: "BaseThreadInitThunk" (+00000012h)
Address: 77DBA9BDh, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "LdrInitializeThunk" (+0000004Dh)
Address: 77D88BF2h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "EtwLogTraceEvent" (+000000FBh)
Address: 77DCB3E3h, location: "ntdll", loaded at 77D80000h - 77E9E000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000645Dh)
Address: 7305286Eh, location: "MSVCR80", loaded at 73050000h - 730EB000h
Symbol: "endthread" (+00000071h)
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Audioscrobbler 1.3.6  (foo_audioscrobbler)
Standard DSP array 1.0  (foo_dsp_std)
freedb Tagger 0.5.2a  (foo_freedb2)
Default User Interface 0.9acc  (foo_ui_std)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Album list panel 0.2.2  (foo_uie_albumlist)
Scheduler 3.53  (foo_scheduler)
FLAC Decoder 1.1.0  (foo_input_std)
Masstagger 1.6  (foo_masstag)
foobar2000 core 0.9.4.3  (Core)
Converter 1.0.1  (foo_converter)
RAR reader 1.1  (foo_unpack)
ABX Comparator 1.3.1  (foo_abx)
CD Audio Decoder 2.1.1  (foo_cdda)
Album List 3.2.0  (foo_albumlist)
Playback Statistics 1.3.2  (foo_playcount)
ZIP/GZIP reader 1.0  (foo_unpack)
WMA Decoder 1.1  (foo_input_std)
Audio CD Writer 2.0.1  (foo_burninate)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
PopUp Plus 20070805  (foo_popupplus)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Illegal operation:
Call path:
This is your 2-nd crash. When reporting the problem to a developer, please try to post info about the first crash instead.
Stack (0528FB70h):
Registers:
Loaded modules:
PROPSYS                          loaded at 74810000h - 748C7000h
Address: 776F5984h, location: "kernel32", loaded at 77660000h - 77738000h
Symbol: "UnhandledExceptionFilter" (+00000000h)
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
i'm using vista, btw. likely the issue.
Reply #61
Thanks for the font options!    I don't have very good eyes, so being able to change font sizes improves usability greatly for me.
Two small feature requests:
  • Please relax the 160px cap on the Minimum width option.
  • (Only if it is not difficult to implement: ) If "Do not close hovered popups" is checked and vanish time is set to a large value, please make the popup reappear if it is hovered while fading out.
Reply #62
Thank you for creating/modifiying this component!
Reply #63
to drake:
hi, at this moment I have no feedback if popup+ worked under vista, I use only xp with sp2. Try to provide crash log generated using debug version of popup+ plugin (foo_popupplus.BUILDDATE.debug.7z) and then I will see.
no problem, but we need some protection against wrong values. Minimum width can be set from 80 to 160px. What is the reason to relax it ?
as I say true, at this moment I don't know what this option is used for (no joke), but I will look at it and then we will see what is possible to do with it.
Reply #64
I like to set large font sizes because I have a small screen (relative to its resolution), so I tried to scale up the minimum width as well (a tall and narrow popup does not look good).  But now I found out that I can do this by editing the skin file, so the problem is solved!
If the "Do not close hovered popups" option is set, the popup will not disappear for as long as the mouse pointer is over it.  It would be nice to be able to "bring back" the popup if the mouse pointer is moved over it during a (long) fade out transition (again, this is similar to how Pretty Popup works).  But look at this only if it not very difficult to implement.  Popup+ (with the current functionality) is already the best popup plugin for foobar2000.
Reply #65
adamh: thx for font and spacing support. popup+ finaly surpassed pretty popup for me in its funcionality  thx... all thing ill ask now are pure feature suggestions
1) in pretty popup there is one nice function which enables users to set actions for l/r/m click on popup. i used this for opening url when i see no album art in popup... now i dont use it almost at all but some others can maybe found it usefull for any reason they may
2) pretty popup has one nice thing that it allows users "drag and drop" positioning of popup. i understand its obsolete now for we have other way to define possition... so take it pls only as suggestion
3) accoring to this page: http://en.wikipedia.org/wiki/BBcode there is command in bbcode named "[size=x]" which allows setting of font size... i understand that bb code was primarly developed for html in which is this command easily implementable but it will be possibly really hard to implement it in stand alone component. i also remeber that youve stated somewhere in this thread that bb code parser isnt primarly you work but can you look into this cmd pls. for its not supported in popup+ ( and i really would like to make title line bigger font than others.
4) last one was requested before so ill just repeat it. pls make a menu entry like "show popup" so we can assign hotkey to it and show popup sometime when we just in middle of track found ourselves courious whats playing right now  thx
Reply #66
a) thanks, I was searching for what this option do, for a long time (too lazy to look into source code).
b) Yes it is an good idea, and of course it is possible to bring popup back and it wouldn't be very complicated. But first I must solve problem where popup is created (I hope that it is the problem). Now it is created in obtained play_callback notification, but it cause track seeking problem if long fade time is set.
Reply #67
hi, first I want to say thanks for your suggestions.
It sould be quite useful, I planing to add a support for popup actions (tiny buttons below notification text).
> 3) accoring to this page: http://en.wikipedia.org/wiki/BBcode there is command in bbcode named "[size=x]" which allows setting of font size... i understand that bb code was primarly developed for html in which is this command easily implementable but it will be possibly really hard to implement it in stand alone component. i also remeber that youve stated somewhere in this thread that bb code parser isnt primarly you work but can you look into this cmd pls. for its not supported in popup+ (and i really would like to make title line bigger font than others.
The problem is not in the command implementation, richedit control is used and if you are able to change color and font "effect" (bold, italic, ...) you will be able to change font size. But if the parser support only simple 'i','b' or 's' bbcode, it should be problem to parse something like 'size=x' or 'color=#xxxxxx'.
I promise, I will look at it.
> 4) last one was requested before so ill just repeat it. pls make a menu entry like "show popup" ...
check for new build (20070808)
Reply #70
I can't seem to change minimum size to more then 160 pixel?!
Reply #71
I have the same problem!Used skin Calipso
Then check Enable Avatars in Skins option. It works for me with build 20070801.
Do not work for me!(XP SP2 ,v0.9.4.3, foo_popupplus.20070808)Used skin Calipso
options
end
Do not work for me.The same problem
The avatar doesn't appear!
The same problem!(XP SP2 ,v0.9.4.3, foo_popupplus.20070808)Used skin Calipso
Reply #72
Album art display works for me (with the Calipso skin too).  Make sure that "Show avatars" is checked at the skin options, and that the cover image file is named "cover.jpg" exactly (and not "cover.jpeg" or something else; set Windows Explorer to show file extensions).  Provided that you did not change the default sources for the cover images, this should work fine.
Please read the previous posts, as this has already been discussed.  At the moment a workaround is to edit the skin file.  E.g. for the Calipso skin, change
 w some_expression
at the beginning of the file to
 w (some_expression) > 200
to set the minimum width to 200 pixels.  See the skin tutorial here.
Reply #73
Yes I'm shure. the file name of my cover is cover.jpg I used default setting of the skin and my cover.jpg is in the same directory as my wavpack file.
Plese help.What is the problem?
Reply #74
don't worry, I will provide special plugin version which creates log. file, where all important settings will be placed. I belive that we find what cause this problem with art.
