Happened again.
I'll try the component for the board but I like the way its part of the Last.fm software :/
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 779DB15Fh
Access violation, operation: write, address: 00000014h
Call path:
Code bytes (779DB15Fh):
779DB11Fh: C0 89 4D F0 0F 84 2C 5B FE FF 8B 4E 04 F6 C1 01
779DB12Fh: 8D 7E 04 0F 85 60 26 FE FF 8B 55 0C 90 8B C1 2B
779DB13Fh: C2 8B D8 8B C1 F0 0F B1 1F 3B C1 0F 85 39 26 FE
779DB14Fh: FF 33 C0 89 45 0C 89 45 08 8B 06 83 F8 FF 74 04
779DB15Fh: 83 40 14 01 8B 5D F4 8B 7D F0 90 80 3D 82 03 FE
779DB16Fh: 7F 00 0F 85 1F B6 03 00 8B 45 FC 83 F8 FF 57 6A
779DB17Fh: 00 0F 84 75 B6 03 00 50 E8 08 55 02 00 3D 02 01
779DB18Fh: 00 00 0F 84 75 B6 03 00 85 C0 0F 8C 0B B7 03 00
Stack (04CBFE04h):
04CBFDE4h: 00000000 00000000 00000000 00000000
04CBFDF4h: 00000000 00000000 00000000 00000000
04CBFE04h: 01890D40 01890D44 00000000 77A01C21
04CBFE14h: 00000000 0189E3D8 0189E3D8 00000010
04CBFE24h: 00000000 04CBFE3C 0000000B C0000008
04CBFE34h: FFFFFFFF 00000002 04CBFDD4 00000000
04CBFE44h: 00000000 00000000 7FFDC000 000003F0
04CBFE54h: 04CBFE7C 779DB071 00000000 00000000
04CBFE64h: 00000000 00000010 01890CE8 00000004
04CBFE74h: 00000000 00000001 04CBFEE0 0066C5AD
04CBFE84h: 01890D40 9A8A8B29 00000000 00000000
04CBFE94h: 01892330 00000000 00004B4F 0000004B
04CBFEA4h: 01890178 00000000 00000002 0000000F
04CBFEB4h: 01890148 077C6A00 018922F8 01892770
04CBFEC4h: 00000000 00000000 0000000F 04CBFE88
04CBFED4h: 04CBFF88 00680178 FFFFFFFF 04CBFF50
04CBFEE4h: 04CBF9AC 00000138 0000013C 04CBFE68
04CBFEF4h: 01890CE8 0000009C 00892330 0000009C
04CBFF04h: 006890A8 504F5453 663D6320 000A6F6F
04CBFF14h: 0189000A 0000000B 0000000F 04CBFF60
Registers:
EAX: 00000000, EBX: FFFFFFFC, ECX: 00000000, EDX: 00000004
ESI: 01890D40, EDI: 01890D44, EBP: 04CBFE54, ESP: 04CBFE04
Crash location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "RtlPcToFileHeader" (+000002E6h)
Loaded modules:
foobar2000 loaded at 00400000h - 00509000h
ntdll loaded at 779A0000h - 77ABE000h
kernel32 loaded at 764B0000h - 76588000h
COMCTL32 loaded at 74AA0000h - 74C34000h
msvcrt loaded at 760D0000h - 7617A000h
ADVAPI32 loaded at 767F0000h - 768AF000h
RPCRT4 loaded at 768B0000h - 76973000h
GDI32 loaded at 75D10000h - 75D5B000h
USER32 loaded at 766D0000h - 7676E000h
SHLWAPI loaded at 77AC0000h - 77B15000h
SHELL32 loaded at 76980000h - 7799B000h
ole32 loaded at 75F80000h - 760C4000h
shared loaded at 10000000h - 1002D000h
COMDLG32 loaded at 76180000h - 761F4000h
IMM32 loaded at 762F0000h - 7630E000h
MSCTF loaded at 76210000h - 762D7000h
LPK loaded at 76200000h - 76209000h
USP10 loaded at 76430000h - 764AD000h
uxtheme loaded at 74DA0000h - 74DDF000h
EVEMon.WinHook loaded at 003A0000h - 003AB000h
mscoree loaded at 79000000h - 79045000h
MSVCR80 loaded at 73850000h - 738EB000h
msvcm80 loaded at 6F060000h - 6F0DD000h
raphook loaded at 00510000h - 00554000h
PSAPI loaded at 75C60000h - 75C67000h
RTSUltraMonHook loaded at 18800000h - 18838000h
foo_albumlist loaded at 012D0000h - 01325000h
foo_audioscrobbler loaded at 00660000h - 00690000h
WS2_32 loaded at 76770000h - 7679D000h
NSI loaded at 766C0000h - 766C6000h
foo_autoplaylist loaded at 01390000h - 013C2000h
foo_browser loaded at 013D0000h - 01409000h
foo_cdda loaded at 015E0000h - 01613000h
foo_channel_mixer loaded at 01620000h - 0165A000h
foo_converter loaded at 01700000h - 01771000h
foo_dsp_delta loaded at 01680000h - 0169E000h
foo_dsp_std loaded at 017B0000h - 017F7000h
foo_dumb loaded at 018A0000h - 01929000h
foo_facets loaded at 01980000h - 01A1C000h
OLEAUT32 loaded at 77B20000h - 77BAC000h
MSIMG32 loaded at 74F60000h - 74F65000h
foo_fileops loaded at 01830000h - 01877000h
foo_freedb2 loaded at 01A20000h - 01A61000h
foo_gep loaded at 01A90000h - 01B2B000h
foo_input_shorten loaded at 01930000h - 0195E000h
foo_input_std loaded at 01C80000h - 01DA3000h
foo_midi loaded at 01E50000h - 01EFA000h
foo_msnalt loaded at 01B30000h - 01B49000h
foo_playcount loaded at 01B50000h - 01B75000h
foo_run loaded at 01BE0000h - 01C0B000h
foo_uie_powerpanels loaded at 01C10000h - 01C33000h
foo_uie_quicksearch loaded at 01F00000h - 01F46000h
foo_uie_vis_projectm loaded at 01F90000h - 01FDC000h
OPENGL32 loaded at 701C0000h - 7028B000h
GLU32 loaded at 74A10000h - 74A33000h
DDRAW loaded at 70350000h - 70436000h
DCIMAN32 loaded at 74890000h - 74896000h
SETUPAPI loaded at 75D60000h - 75EE8000h
dwmapi loaded at 74D60000h - 74D6C000h
foo_ui_columns loaded at 02010000h - 020A7000h
foo_ui_panels loaded at 021B0000h - 02299000h
gdiplus loaded at 74550000h - 746FA000h
foo_ui_std loaded at 02320000h - 023D6000h
foo_unpack loaded at 01DE0000h - 01E0E000h
foo_utils loaded at 02A00000h - 02A78000h
foo_version loaded at 020B0000h - 020D6000h
dbghelp loaded at 71F10000h - 71FEC000h
foo_whatsnew loaded at 020E0000h - 02111000h
UltraMonRes loaded at 19000000h - 1900E000h
PROPSYS loaded at 74490000h - 74547000h
apphelp loaded at 75B00000h - 75B2C000h
CLBCatQ loaded at 75EF0000h - 75F74000h
wpdshext loaded at 6D1B0000h - 6D411000h
WINMM loaded at 74820000h - 74853000h
OLEACC loaded at 747E0000h - 74818000h
shdocvw loaded at 713B0000h - 714B7000h
ieframe loaded at 6C7C0000h - 6CD8B000h
iertutil loaded at 767A0000h - 767E5000h
USERENV loaded at 75BB0000h - 75BCE000h
Secur32 loaded at 75B90000h - 75BA4000h
urlmon loaded at 76590000h - 766BF000h
IPHLPAPI loaded at 755A0000h - 755B9000h
dhcpcsvc loaded at 75560000h - 75595000h
DNSAPI loaded at 757D0000h - 757FB000h
WINNSI loaded at 75550000h - 75557000h
dhcpcsvc6 loaded at 75530000h - 75550000h
mswsock loaded at 75360000h - 7539B000h
rasadhlp loaded at 73C00000h - 73C06000h
DSOUND loaded at 6F120000h - 6F191000h
POWRPROF loaded at 75050000h - 7506A000h
MMDevApi loaded at 74750000h - 74777000h
WINTRUST loaded at 74EA0000h - 74ECD000h
CRYPT32 loaded at 75650000h - 75741000h
MSASN1 loaded at 75790000h - 757A2000h
imagehlp loaded at 77BB0000h - 77BD9000h
audioses loaded at 73340000h - 73361000h
audioeng loaded at 732D0000h - 73336000h
AVRT loaded at 747D0000h - 747D7000h
rsaenh loaded at 750F0000h - 75128000h
Stack dump analysis:
Address: 77A01C21h, location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "RtlTryEnterCriticalSection" (+0000033Bh)
Address: 779DB071h, location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "RtlPcToFileHeader" (+000001F8h)
Address: 0066C5ADh, location: "foo_audioscrobbler", loaded at 00660000h - 00690000h
Symbol: "foobar2000_get_interface" (+00007DFDh)
Address: 00680178h, location: "foo_audioscrobbler", loaded at 00660000h - 00690000h
Symbol: "foobar2000_get_interface" (+0001B9C8h)
Address: 0066E3F3h, location: "foo_audioscrobbler", loaded at 00660000h - 00690000h
Symbol: "foobar2000_get_interface" (+00009C43h)
Address: 0066C8C9h, location: "foo_audioscrobbler", loaded at 00660000h - 00690000h
Symbol: "foobar2000_get_interface" (+00008119h)
Address: 0066FE0Ah, location: "foo_audioscrobbler", loaded at 00660000h - 00690000h
Symbol: "foobar2000_get_interface" (+0000B65Ah)
Address: 006749C0h, location: "foo_audioscrobbler", loaded at 00660000h - 00690000h
Symbol: "foobar2000_get_interface" (+00010210h)
Address: 0066FEAFh, location: "foo_audioscrobbler", loaded at 00660000h - 00690000h
Symbol: "foobar2000_get_interface" (+0000B6FFh)
Address: 764F3833h, location: "kernel32", loaded at 764B0000h - 76588000h
Symbol: "BaseThreadInitThunk" (+00000012h)
Address: 779DA9BDh, location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "LdrInitializeThunk" (+0000004Dh)
Address: 779A8BF2h, location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "EtwLogTraceEvent" (+000000FBh)
Address: 779ED845h, location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "RtlConvertUlongToLargeInteger" (+000088BFh)
Address: 0066FE30h, location: "foo_audioscrobbler", loaded at 00660000h - 00690000h
Symbol: "foobar2000_get_interface" (+0000B680h)
Address: 01B6D3E8h, location: "foo_playcount", loaded at 01B50000h - 01B75000h
Symbol: "foobar2000_get_interface" (+00016F88h)
Address: 01B6D7E8h, location: "foo_playcount", loaded at 01B50000h - 01B75000h
Symbol: "foobar2000_get_interface" (+00017388h)
Address: 01B6D700h, location: "foo_playcount", loaded at 01B50000h - 01B75000h
Symbol: "foobar2000_get_interface" (+000172A0h)
Address: 779D49D5h, location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "RtlEncodePointer" (+00000000h)
Address: 779D0A18h, location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "RtlDecodePointer" (+00000000h)
Address: 01B60005h, location: "foo_playcount", loaded at 01B50000h - 01B75000h
Symbol: "foobar2000_get_interface" (+00009BA5h)
Address: 01B60008h, location: "foo_playcount", loaded at 01B50000h - 01B75000h
Symbol: "foobar2000_get_interface" (+00009BA8h)
Address: 01B6E5ECh, location: "foo_playcount", loaded at 01B50000h - 01B75000h
Symbol: "foobar2000_get_interface" (+0001818Ch)
Address: 779D0041h, location: "ntdll", loaded at 779A0000h - 77ABE000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+000000CFh)
Address: 01B60053h, location: "foo_playcount", loaded at 01B50000h - 01B75000h
Symbol: "foobar2000_get_interface" (+00009BF3h)
Version info:
foobar2000 v0.9.5 beta 3
UNICODE
Windows 6.0
Additional info:
projectM visualization (Panel) 0.4 (SSE2) (foo_uie_vis_projectm)
freedb Tagger 0.5.2.1 (foo_freedb2)
Seek Panel 0.1 (foo_uie_powerpanels)
Converter 1.0.1 (foo_converter)
Columns UI 0.1.3 beta 1v7 (foo_ui_columns)
foobar2000 core 0.9.5 beta 3 (Core)
Standard Input Array 1.0 (foo_input_std)
MSN Now Playing (alt) 2.4 (foo_msnalt)
Album List 4.1 (foo_albumlist)
Game Emu Player 1.5 (foo_gep)
Components versions viewer 0.3 (foo_version)
ZIP/GZIP reader 1.0 (foo_unpack)
MIDI synthesizer host 1.7 (foo_midi)
Default User Interface 0.9.5 (foo_ui_std)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56] (foo_browser)
Feature Watcher 1.0.3 (foo_whatsnew)
Shorten decoder 0.4.2a (foo_input_shorten)
Quick Search Toolbar 2.8k (foo_uie_quicksearch)
LPCM <--> delta-PCM converter 0.1.1 (foo_dsp_delta)
Playback Statistics 2.0 (foo_playcount)
Standard DSP Array 1.0 (foo_dsp_std)
Run services 0.3.2 (foo_run)
File Operations 2.0 (foo_fileops)
Channel Mixer 0.9.4 (foo_channel_mixer)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00] (foo_ui_panels)
CD Audio Decoder 2.1.2 (foo_cdda)
Playlist Tools 0.6.2 beta 1 (foo_utils)
Audioscrobbler 2.1 (foo_audioscrobbler)
RAR reader 1.1 (foo_unpack)
DUMB module decoder 0.9.8.4 (foo_dumb)
Facets 2007-10-20 (foo_facets)
Volume Panel 0.1 (foo_uie_powerpanels)
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Added codebox.
Closing this thread as the component has been in our broken components list for months and Last.fm apparently decided to ignore it.[/size]
