Topic: Cover size (Read 4816 times) previous topic - next topic
Cover size
How get size and dimension cover in tag in a component?
Re: Cover size
There is a component called Cover Utils, but it is currently unavailable (for some reason).
Cover Utils
https://marc2k3.github.io/component/cover-utils/
Download
foo_cover_utils-1.1.fb2k-component
https://github.com/marc2k3/marc2k3/releases
I was able to display the size using [%cover_utils_front_width% x %cover_utils_front_height%].
With the old version v2.15 or v2.1.4, the message "Install component has been damaged" appears and foobar2000 cannot be started.
@marc2003
"Cover Utils" Please correct this.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Re: Cover size
Ty but I referer to a source code for embedded images.
Re: Cover size
Everything you posted is complete and utter bollocks.
First of all, this thread is in the development section. The OP did not want another component to do it.
Then you posted direct links while simultaneously saying it was not available.
And the page clearly states 2.24 is required.
And people wonder why I don't have the patience for this shit.
Re: Cover size
@marc2k3
Latest Latest
Requirements
> These components require foobar2000 2.24 and Windows 10 or later. 32bit and 64bit are both supported.
Oops, big mistake
This line was extra.
Well, let's leave that aside.
But it doesn't work with foobar2000 v2.24.1. Nothing is displayed.
Please TEST it. If it doesn't show up, please fix it.
So it's not that bad.
I think more people are now thinking, "I see."
I am used to being despised, insulted and ridiculed by you for my lack of knowledge. Please hear my help now.
Re: Cover size
@Forfit
If your foobar version is v2.24 or v2..24.1, will it show the size of the cover?
Use:
Anyone can tell me if they have tested it and whether it was displayed or not.
Re: Cover size
@Air KEN : it feels like you skipped instructions for the component: https://marc2k3.github.io/component/cover-utils/#scan-for-info
@Forfit : as far as I can see, you need to figure out best method to parse the dimensions you are after from the image data you get from the album art API. foobar2000 for example uses WIC for image handling on Windows.
Re: Cover size
I would get cover size in a variable %cover_size% to use in playlist.
Re: Cover size
@Case
Case, you can display it, right?
Yes, I have read that page many times.
I used it before. I didn't know that there was an update to foobar2000 v2.24.
Rescanning the database didn't help either.
I'm starting to think that the title formatting is different.
No one has said that you can display the size using Cover Utils, right?
Re: Cover size
I just verified now with both 32-bit and 64-bit foobar2000 versions, seems to work as documented. After scanning for info your [%cover_utils_front_width% x %cover_utils_front_height%] string worked fine. Size info was missing only from files without embedded art.
Re: Cover size
@Case
Become even more depressed. orz
Re: Cover size
@Case
Custom text added:
[$crlf()$crlf()cover %cover_utils_front_width% x %cover_utils_front_height% size $replace(%cover_utils_front_size%, ,)]
Works for me after scanning with context  menu Cover Utils \ Scan for Cover Info for files with embedded Front Cover.
I wonder however how to show this info for external found Front Cover.
Re: Cover size
@Defender
Of course I did.
I am a fool. ord
Is Forfit doing well?
Since this is a Forfit thread I'll step back.
I am a fool...I am a fool....I am a fool...
