Topic: How can you delete UI element? (Read 15521 times) previous topic - next topic
Sorry ... probably a stupid question but I have been learning foobar and I split a UI element creating another one, but now want to remove it. How can I delete it? When I right click on it all I have is the option to "Cut UI element" but I want to actually remove the one created by the split option.
You got the panel via adding a splitter, you remove it by removing the splitter - not the panel. It can be a little tough to grab the splitter and not the panel, but the change in the cursor will help you right click at the right time.
Removing the splitter would remove the two panels split by the splitter.
Perhaps he wants to cut the desired UI element and paste it in place of the splitter.
elevatorladylevitateme
Thanks tpijag. Thats what I was after. Appreciate both replies.
