HydrogenAudio
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: yurithedragonhalf on 2013-08-15 17:38:59
Title: ESplaylist album art search patterns
Post by: yurithedragonhalf on 2013-08-15 17:38:59
Ok I recently joined club SSD and i lost/forgot most of my search patterns basically i need to look for any album art with the word front in it even if it's in ( ) or [ ]
thanks!
Post by: marc2003 on 2013-08-16 03:33:30
file>preferences>display>album art
*front*.*
Post by: yurithedragonhalf on 2013-08-16 19:01:00
I've got that one but it doesn't seem to work even when the file name has "front" in it.
Post by: marc2003 on 2013-08-16 20:48:56
it works for me.
you can check:
-that you definitely added it to the front section in the artwork preferences and that EsPlaylist is also configured to show the front. that can be changed somewhere in the advanced grouping settings.
-no other image files are taking precedent by being first. entries are processed in order from top to bottom and it stops whenever a pattern that matches is encountered.
-that the images live in the same folder as the actual audio files.
Post by: yurithedragonhalf on 2013-08-16 22:16:57
This is what i have set up
(http://i.imgur.com/1xA5Gkt.png) (http://i.imgur.com/s0EHZ0j.png)
anything wrong?
Post by: marc2003 on 2013-08-17 05:37:55
go back to my first post.
these are the global settings for all of foobar. you've been using the columns UI settings.
Post by: yurithedragonhalf on 2013-08-17 09:15:48
ah thanks!
