Topic: cue file editing is not working (Read 1555 times) previous topic - next topic
FB 1.4 b15
If I load a cue file to the editor screen it looks fine. after 'OK' FB reads and appears to use it, but the album list doesn't then see the tracks, and if I open the cue editor again, the contents have been rewritten to all show the album name for each track name.
Removing the embedded cue file has no effect.
Re: cue file editing is not working
What exact file type is it? Is it a FLAC file?
That can happen if file you want to add cue has tags. So first remove tags from single flac file and then add cue again.
And if you've already added cue you should:
remove embedded cue > remove tags from file > add cue
Somewhere, there's someone dying in a foreign land
Meanwhile, the world is crying stupidity of man
Tell me why, tell me why
Yes - FLAC files as far as I have seen.
I'll try the tag removal
yes - clearing tags/clearing cue file/adding cue file works.
(has FB a clear tags option somewhere?)
It has but it is disabled by default. You can enable it at Preferences / Display / Context menu / Tagging
If you still have the original file where editing cuesheet yelds incorrect results, I'd like to have a copy of it.
