New EAC is out.
http://www.exactaudiocopy.de/en/index.php/...urces/download/ (http://www.exactaudiocopy.de/en/index.php/resources/download/)
Changelog
Finally here is the new version 1.0 beta 1 which has some mighty new features. I took some time (mainly the complete change to unicode character set), but alls well that ends well…
Here comes a list of the new features:
+ Unicode support for all fields (but not CD-Text)
+ New database engine for storing CD information (old databases can be imported)
+ Metadata plugin support, for now there is a freedb plugin included. This will be released as open source freeware soon.
+ Cover support, can be drag’n'dropped from a file, a web page oder can be retrieved via a metadata plugin (support included in the freedb plugin). Cover can be written into tags or in the extraction directory
+ AccurateRip v2 support
+ Better Windows 7 support (like progress display in taskbar icon, storage of user data in the correct folders, etc.)
+ Free selection of first track track number (including option to continue numbering from the last inserted CD)
+ Option to always write the log file in english language
+ Option for writing a checksum over the extraction log data to the log file
+ Average extraction speed is listed in the log file
+ Possibility to write only V2 tags (and no V1 tags)
+ Free choice of replacement characters for filenames
+ Range copy selects now the first selected consecutive range of tracks as default
+ New folder browser dialog (system dialog for folders)
+ Added two placeholders for filename creation for track length (min and sec)
+ Test for (command line) compression options (and display of a sample command line)
+ Menu for removing unwanted/doubled spaces from “cd title”, “artist” & “track titles”
And some features are now removed:
- Removed Windows 2000 support (and any older OSs)
- Removed ID3V1 tag editor
- Removed compression offset
Hope you like it!
The next version is also planned, it will mainly contain an additional demo for a commercial metadata provider (if anybody would like to have access)
more info:
http://forums.slimdevices.com/showthread.php?t=83446 (http://forums.slimdevices.com/showthread.php?t=83446)
Checked briefly and it looks same to me (of course changelog), only don't know why it ask .NET 2.0 support
I'm used to 0.95pb3 afterall and don't need to reconfigure from ground for something I don't really feel missing
I believe this is support of the new CRC, rather than CRC and cross-pressing checking.
everything i hoped for so long is not implemented.
- embedding log files to image encodings (wavpack, flac) is still not possible, because encoding process starts before the file is written and therefore cannot be found by the encoder
- custom filenames when ripping images is still not available
anyway nice to see that the development is not dead.
AFAIK .NET is only needed for the "Metadata plugin", which you can unselect during install.
And indeed it is very frustrating that none of the previous settings can be "migrated" to this version.
more info:
I find it at least "adventurous" to link to the Slimdevices forum for "more info"
I already asked there. During ripping a cd and encoding with flacuda as external encooder i get 2 beeps after every song. I find this a bit annoying. Does this indicate an error? All seems to work fine to me.
whats flacuda? eac seems to come with stock flac 1.2.1
is flacuda some kind of nvidia gpu thing?
in EAC options on the general tab there is a checkbox for "beep when finished extracting" which i have unchecked, but that sounds different than your issue.
Happens with standard flac also. It encodes, closes the window and gives 2 beeps while going on ripping the next song. Test encoder gives no error back. So it must be a new "feature"
Disabling "beep when finishing..." disables all beeps.
Having some kind of signal at the end of a complete rip makes sense but after every song?
I found why. My fault, sorry.
If i choose "On extraction start external compessors queued in the background" it indicates the end of the encoding i suppose. No way to disable the beeps then.
nice to see. I'll have to give it a try as its been awhile since I have used EAC
could you not go in to the device manager, change the view to show hidden devices and expand non-plug and play drivers. double click beep, click the driver tab and click stop on the current status and change startup to disabled.
I get much lower AR confidence with the new version: 6, with older EAC it was 200. ("Kind of Blue", 1997 remaster)
Why is this so? Does it only count AR 2 rips?
I did a fresh install and the wizard didn't ask me to insert a CD to test for offset, like it did with the older version.
Disabling "beep after extraction finished" in EAC General settings disables all beeps, like mentioned above. It also disables the beep when finished.
I haven't tried it yet, but most likely its only reporting AR2 results. Post your log, that may help to answer your question.
There you go, old and new one:
Exact Audio Copy V0.99 prebeta 5 from 4. May 2009
EAC extraction logfile from 5. October 2010, 21:36
Miles Davis / Kind of Blue (1997 Remaster)
Used drive : TSSTcorpCDDVDW SH-S223C Adapter: 3 ID: 1
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 697
Overread into Lead-In and Lead-Out : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -8 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "GENRE=%m" -T "COMMENT=%e" %s -o %d
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 9:25.00 | 0 | 42374
2 | 9:25.00 | 9:49.05 | 42375 | 86554
3 | 19:14.05 | 5:37.42 | 86555 | 111871
4 | 24:51.47 | 11:35.58 | 111872 | 164054
5 | 36:27.30 | 9:26.10 | 164055 | 206514
6 | 45:53.40 | 9:31.65 | 206515 | 249404
Track 1
Filename E:\Miles Davis - 1959 - Kind of Blue (1997 Remaster) [FLAC]\01 - So What.wav
Pre-gap length 0:00:02.00
Peak level 94.4 %
Track quality 100.0 %
Copy CRC 33D07D6F
Accurately ripped (confidence 200) [BF9E60B7]
Copy OK
Track 2
Filename E:\Miles Davis - 1959 - Kind of Blue (1997 Remaster) [FLAC]\02 - Freddie Freeloader.wav
Pre-gap length 0:00:02.45
Peak level 94.4 %
Track quality 99.9 %
Copy CRC 75392A2B
Accurately ripped (confidence 200) [002094C4]
Copy OK
Track 3
Filename E:\Miles Davis - 1959 - Kind of Blue (1997 Remaster) [FLAC]\03 - Blue in Green.wav
Pre-gap length 0:00:02.43
Peak level 89.8 %
Copy CRC E1F23CF0
Accurately ripped (confidence 200) [93B6B811]
Copy OK
Track 4
Filename E:\Miles Davis - 1959 - Kind of Blue (1997 Remaster) [FLAC]\04 - All Blues.wav
Pre-gap length 0:00:00.30
Peak level 94.4 %
Copy CRC ED3A457F
Accurately ripped (confidence 200) [A7F414E2]
Copy OK
Track 5
Filename E:\Miles Davis - 1959 - Kind of Blue (1997 Remaster) [FLAC]\05 - Flamenco Sketches.wav
Pre-gap length 0:00:02.60
Peak level 94.4 %
Copy CRC 1AF426CC
Accurately ripped (confidence 200) [43D67A72]
Copy OK
Track 6
Filename E:\Miles Davis - 1959 - Kind of Blue (1997 Remaster) [FLAC]\06 - Flamenco Sketches (Alternate Take).wav
Pre-gap length 0:00:00.05
Peak level 94.4 %
Copy CRC BECFF81F
Accurately ripped (confidence 200) [27325B41]
Copy OK
All tracks accurately ripped
No errors occurred
End of status report
Exact Audio Copy V1.0 beta 1 from 15. November 2010
EAC extraction logfile from 24. November 2010, 13:36
Read mode : Secure
Selected bitrate : 768 kBit/s
Quality : High
Add ID3 tag : No
Additional command line options : -8 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "GENRE=%m" -T "COMMENT=%e" %j--picture="%i"%j %s -o %d
Track 1
Peak level 94.4 %
Extraction speed 2.3 X
Copy CRC 33D07D6F
Accurately ripped (confidence 6) [BF9E60B7]
Copy OK
Track 2
Peak level 94.4 %
Extraction speed 2.1 X
Copy CRC 75392A2B
Accurately ripped (confidence 6) [002094C4]
Copy OK
Track 3
Peak level 89.8 %
Extraction speed 2.2 X
Copy CRC E1F23CF0
Accurately ripped (confidence 6) [93B6B811]
Copy OK
Track 4
Peak level 94.4 %
Copy CRC ED3A457F
Accurately ripped (confidence 6) [A7F414E2]
Copy OK
Track 5
Peak level 94.4 %
Copy CRC 1AF426CC
Accurately ripped (confidence 5) [43D67A72]
Copy OK
Track 6
Peak level 94.4 %
Copy CRC BECFF81F
Accurately ripped (confidence 6) [27325B41]
Copy OK
No errors occurred
==== Log checksum 508E1F35E1266DAA435F908F2DC1D9FA37509DD38146ED590977D962552483D2 ====
The checksums for tracks are the same.
If AR2 is present in the database, new EAC will report that; if not, it will report AR1 values.
Unless there is some other bug, it appears as if the new log is only reporting the confidences of the AR2 hashes and not the AR2 hashes themselves, since the hashes being shown are obviously AR1.
Andre needs to indicate which CRC it is showing, a simple (AR2) would suffice if is the new CRC
On Windows 7 (64-bit) opening a file dialog inside the software invariably crashes the software thus making it impossible to use other external encoders than the preselected flac.
This is still better than the last 0.99 beta that hanged during the Feature Detection of my blueray-player (HT-DT-STBD-RE GGW-H20L).
On the bright side, "Browse for Folder" dialog doesn't crash
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: EAC.exe
Application Version: 0.0.0.0
Application Timestamp: 00000007
Fault Module Name: unknown
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 038dbfc1
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1035
Cannot replicate this issue on Windows 7 x64... file dialogs in the external decoders window work as expected.
That said, unfortunately this release appears to remove the option to store a local (flat file) freeDB database, which is not something I can easily give up after having it available for so long.
Nice! I'll have to try this one soon.
I have .99 installed in a stand alone folder so the new install won't trash it.
You can safely have both 1.0 and a previous version installed at the same time so long as you have them in separate directories. The settings for 1.0 are kept in a separate space in the registry.
Hopefully because when I was using the last two .9x versions, they both wrote to the same registry space.
@ greynol, I miss your old quite distinctive Gargamel and Azrael avatar.
LOL. I have a batch script that maintains entries for two versions that I typically use: V0.95 and V0.99.
I can't rip or do any stuff with the new EAC. I can't make cue files and when EAC should start ripping it just hangs and I have to restart the program. I am on Windows 7 x64 and have a "Optiarc DVD RW AD-7173A 1-04" and I use the drive profile which EAC recognizes which correct offset etc. Anyone else having the same problem? Regards
Same for me on Windows 7 x86. It can play the CD and identify it but when I go to rip, it freezes.
If you haven't, you should try the official forum (http://www.digital-inn.de/forum14/) since I don't think Andre reads this one.
What drive letter do you have associated with the drive you're trying to use to rip?
I fresh installed v1.0 and set it up from scratch. Worked great and I loved the album art search and copy to the music folder feature.
No issues yet as I've only ripped a few CDs to WavPack and V1 LAME VBR. I also like the feature of advancing the track numbers on the subsequent discs so it can all be put into one play folder. I had to edit the playlist by combining the separate disc tracks in one file.
Q6600 processor, Win7 x64 Pro, 8GB of memory.
Can anyone hazard a guess as to why, even though I have "Delete WAV after compression" checked, EAC does not delete the WAVs, and furthermore, just to rub it in, gives all my flac files random 9-character filenames starting with #tmp? (FWIW the WAVs are named perfectly)
...EAC does not delete the WAVs, and ...gives all my flac files random 9-character filenames starting with #tmp?
One thing that will cause this is extra characters (like a space) entered at
Compression Options --- External Compression tab --- Use file extension: ________Make sure the text box has nothing but ".flac"
Thanks, that did the trick
no zip file?
Unpack the installable .exe file with 7zip
Which EAC.exe.manifest is installed? The new one does not have the freedb tag section.
v1 beta2 is now out:
