Topic: Undelete a desktop folder (Read 2428 times) previous topic - next topic
I accidentaly deleted and empotied the recycle bin in Windows ME.  Can I get it bhack??  How??
Nov schmoz kapop.
You can try some software to undelete deleted data. Some such software you may find here:
http://www.brothersoft.com/search.asp?keyword=undelete
The problem is that deleted data will be recoverable only if other data will be not saved on the place of deleted data. So this is very important to do not install new programs and copy something on the partition where you want recover files...
@WILU -  Which one works the best??
Nov schmoz kapop.
They all work the same way. Idea of working of these programs is that files are not deleted from disk but only first letter of their name is erased from partition table.
Try Easy Recovery PE:
ftp://files.chip.pl/9175/Erperfus.exe
@WILU  Thanks for the tip.  I asked about "which one" because some software is just better than others.  I am d/l'ing easyrecover now.  Hopefully it will do  the job.
Nov schmoz kapop.
Try to install it to other partition than this where you have files you want to recovery. It's very important to not overwrite them with newer files.
Happy recovery
