Is it mostly just the playlist title formatting you're interested in? If so, you can grab this older version of my config here. Most of the title formatting in the playlist is the same (only some small changes and optimizations here and there have been done since, with that part). If you want the entire thing, I'll have to clean it up a little more and all that before uploading it anywhere
Could you please share field value for decade filter?
Sure thing, here you go:
// Alternative color for undated track ect. + a char to bump to top
$puts(c2,$char(8203)$rgb(140,150,160,70,75,80))
$if(%date%,
$ifgreater(%date%,2029,
$get(c2)'( Post-2029 )'
$ifgreater($select($sub(1910,%date%),1,2,3,4,5,6,7,8,9,10),0,'1900-1909',
$ifgreater($select($sub(1920,%date%),1,2,3,4,5,6,7,8,9,10),0,'1910-1919',
$ifgreater($select($sub(1930,%date%),1,2,3,4,5,6,7,8,9,10),0,'1920-1929',
$ifgreater($select($sub(1940,%date%),1,2,3,4,5,6,7,8,9,10),0,'1930-1939',
$ifgreater($select($sub(1950,%date%),1,2,3,4,5,6,7,8,9,10),0,'1940-1949',
$ifgreater($select($sub(1960,%date%),1,2,3,4,5,6,7,8,9,10),0,'1950-1959',
$ifgreater($select($sub(1970,%date%),1,2,3,4,5,6,7,8,9,10),0,'1960-1969',
$ifgreater($select($sub(1980,%date%),1,2,3,4,5,6,7,8,9,10),0,'1970-1979',
$ifgreater($select($sub(1990,%date%),1,2,3,4,5,6,7,8,9,10),0,'1980-1989',
$ifgreater($select($sub(2000,%date%),1,2,3,4,5,6,7,8,9,10),0,'1990-1999',
$ifgreater($select($sub(2010,%date%),1,2,3,4,5,6,7,8,9,10),0,'2000-2009',
$ifgreater($select($sub(2020,%date%),1,2,3,4,5,6,7,8,9,10),0,'2010-2019',
$ifgreater($select($sub(2030,%date%),1,2,3,4,5,6,7,8,9,10),0,'2020-2029',
$get(c2)'( Pre-1900 )'
$get(c2)'( Undated songs )'
Just remove the top comment and linebreaks, and it should be ready for use I'm sure there could be better ways to do this, but at least it works. If you want to add more decades, just remember to also add a parenthesis on the line below "pre-1900."
