Topic: Errer opening ogg files (Read 3531 times) previous topic - next topic
Dears,
When I play ogg files with fb2k, some ogg files are not worked.( Of course I can play those with Winamp)
When I add directories or files, playlist shows those ogg files but timelength displays as '0' and if I push play button
popup console box says 'Error open file for...'
What should I do with this?
Now I like fb2k much more than Winamp and I want to play ogg files with fb2k.
Could anyone help me?
Thanks in advance.
There may be some other reason but probably this is the source of your problem (from fb2k changelog):
- following Xiph's recommendations, Ogg files containing garbage at the beginning no longer play
If so, I can guess that there are ID3v2 tags inserted which are obviously invalid for Ogg container. Try to remove them (or convert to proper ogg file comments). This tool can be helpful.
A Korean page which directs to the ID3Kill home page... Which is now a dead project. The last version is still available, but the author directs people to the exact same tool that Messer suggested, Tag.
I've got it, thanks guys.
(yeh it was the id3 tag ploblem)
Unfortunately, this problem occurs due to software the likes of which should not exist, such as C***P*****, which writes ID3v2 tags onto OGG files. Not even the last version corrected the problem.
