Topic: Part of Compilation (Column / TAG) (Read 970 times) previous topic - next topic
Hi all.
Please, is there a variable to add an information for 'Part of Compilation" as in the picture below (from TagScanner)?
Evidently, it doesn't need to be a 'check box'. It would be enough if it were some variable that could include some information, for example, "yes", if it were really part of a compilation.
Thanks in advance.
Re: Part of Compilation (Column / TAG)
Hi there,
You can add a new field in right-click track > Properties. What file type are you tagging?
According to Tag Mapping, you could probably just use COMPILATION for everything.
However beware there is also ITUNESCOMPILATION. On MP3 / ID3 tags foobar maps that to TCMP frame, according to ID3 Tag Mapping.
(I'm not sure if using COMPILATION on MP3 files whether foobar writes it to TCMP frame? Also I'm not sure which field Tag Scanner is reading there)
Both fields should have a value of 1, or nothing at all. Of course you can display it in foobar however you like -
$if(%compilation%,Yes)
Cheers
Hi there,
I'm tagging everything, so I think COMPILATION will work for me!
Many, many thanks!!!
