Topic: ColumnsUI Filters remove Scrollbars alternative (Read 1458 times) previous topic - next topic
Hello,
the Columns UI Filter Component have scrollbars which destroy my layout. I think it is not possible to remove them. Is there any alternative plugin to achieve the same?
Re: ColumnsUI Filters remove Scrollbars alternative
Not if you want to stick with columns ui.
There is a sorta workaround but it requires work. You can encapsulate each filter window in its own panel stack splitter and extend it beyond the horizontal splitter size which would hide the scrollbar underneath the splitter. Repeat for each filter window.
With panel stack splitter it is possible to remove the scrollbars. But then the filters are not any longer connected. Is there anythink I can do about it?
I created something with the graphical browser plugin. But the solution is not good enough.
Is there an other solution maybe with WSH Panel?
What do you mean with "connected"? Connected in a functional sense or a graphical sense? Why would that be an issue?
Strange you'd suggest WSH panel.
I mean it in a  functional sense. Every filter shows now everything from the whole libary. Without take note of the previous selection.
It shouldn't do that if you set filter precedence  by field list above and not by position in splitter.
