Topic: exhale - Open Source USAC encoder (Read 318761 times) previous topic - next topic
Re: exhale - Open Source USAC encoder
Reply #150
no, I'm not interested in unknown formats. Thanks the same.
Reply #151
@celona
Can I ask you? What this all bitrate tables vs sampling rates about?
It's trivial to indicate the bitrate/file size to some particular sampling rate of one particular codec by changing settings.  What is not trivial is too see which quality it produces for a given codec (and your table doesn't show that).
Higher sampling rate doesn't mean higher quality in context of lossy formats.
Reply #152
Right observation, I provided the source files in a previous message, you can get the result and compare it with yours from the terminal with the command:
opusenc --speech source target
or:
opusenc --music source target
Doing so will not remain unknown even the unacceptable distortion that the Opus encoder inserts where our hearing is most sensitive.
I propose them here again:
8 kHz - https://hydrogenaud.io/index.php?action=dlattach;attach=17022
12 kHz - https://hydrogenaud.io/index.php?action=dlattach;attach=17023
16 kHz - https://hydrogenaud.io/index.php?action=dlattach;attach=17024
24 kHz - https://hydrogenaud.io/index.php?action=dlattach;attach=17025
32 kHz - https://hydrogenaud.io/index.php?action=dlattach;attach=17026
48 kHz - https://hydrogenaud.io/index.php?action=dlattach;attach=17027
Reply #153
@celona
I will reply by showing the meaning of the experiment with the numbers. For now sorry.
Reply #154
Exhale @a8511608
# 8 12 16 24 32 48 kHz
1
2
Reply #155
Exhale @a8511608
3
4
Reply #156
Exhale @a8511608
5
6
Reply #157
Exhale @a8511608
7
8
Reply #158
Exhale @a8511608
9
Reply #159
Sorry, how long is this to continue?
Please, get to the point.
Reply #160
Exhale @a8511608
I'm done, in the previous messages I have linked the file to feel the differences that I will write in the future.
Stereo8 kHz12 kHz16 kHz24 kHz32 kHz48 kHzEncoder
AAC-xHE USAC187 kB260 kB351 kB428 kB476 kBNoneexhale 1
AAC-xHE USAC208 kB291 kB396 kB484 kB584 kB572 kB exhale 2
AAC-xHE USAC269 kB383 kB528 kB656 kB740 kB706 kB exhale 3
AAC-xHE USAC303 kB435 kB597 kB740 kB795 kB789 kB exhale 4
AAC-xHE USAC415 kB600 kB816 kB994 kB958 kB951 kBexhale 5
AAC-xHE USAC521 kB762 kB1 MB1.2 MB1 MB1 MBexhale 6
AAC-xHE USAC1.1 MB1.6 MB2.1 MB1.6 MB1.1 MB1.1 MBexhale 7
AAC-xHE USAC29 kB43 kB55 kB78 kB1.2 MB1.3 MBexhale 8
AAC-xHE USAC29 kB43 kB55 kB77 kB1.2 MB1.4 MBexhale 9
Opus --music447 kB490 kB604 kB552 kB600 kB750 kBopusenc
Opus --speech285 kB327 kB466 kB551 kB600 kB750 kBopusenc
Wave (original)1.9 MB2.9 MB3.8 MB5.8 MB7.7 MB11.5 MBffmpeg
When the file size changes significantly something went wrong and the quality collapsed. Typically when the bitrate drops, as in the case of Opus --speech, the artifacts become evident.
Reply #161
Thanks, celona. I skimmed through your posts and collected some mono files for comparison which are similar in file size and not obviously broken/buggy in sound quality:
  • spoken-m-24k-aac, AAC / LC, 33 kbps (260.545 bytes),
  • spoken-m-24k-aace, AAC / ELD, 32 kbps (259.128 bytes),
  • spoken-m-24k-aacf, AAC / ELD + LD-SBR, 32 kbps (258.762 bytes),
  • spoken-m-24k-aacl, AAC / LD, 33 kbps (261.083 bytes),
  • spoken-m-48k-aach, HE-AAC, 33 kbps (257.456 bytes),
  • spoken-m-32k-usac, xHE-AAC, 33 kbps (256.471 bytes).
The first five files I got from one of your earlier posts, the last one was created with a 1.0.4 beta version of exhale from the 32-kHz mono original you posted here and is attached to this post (exhale can encode 32 kHz at mode 1 now, and the resulting bit-rate is closer to the 32 kbps target for this example than with 24 kHz sampling rate).
Chris
Reply #162
Blather and related discussion has been split to the Recycle Bin.
You are very polite, I will remember before writing again.
Reply #163
Sorry, I was told to do it. I should have just left it.
@celona You can reply, I should just leave well enough alone.
Reply #164
Last commits have significant imrpovements, especially on transient files (at least for my ears.) https://gitlab.com/ecodis/exhale/-/commits/master
It would be great if someone else will perform some blind tests on attached samples (EIG and castanets) and  confirm this.
Reply #165
After a short test I have the same impression. Tonight I will listen again.
Reply #167
celona's previous tests were of remote usefulness, in tracking general data complexity, but not necessarily for how audible the compression is or is not. Sudden size changes across commits could be a sign of a regression, or simply a new optimization that improves compression without affecting audio quality.
Yes, it is best to perform ABCHR or similar double blind tests to verify whether such changes are actually audible, or if it's just a side benefit of improvements.
Reply #168
celona's previous tests were of remote usefulness, in tracking general data complexity... Sudden size changes across commits could be a sign of a regression...
Indeed, he pointed me to an issue with combinations of high bit-rate and low sampling rate. Thanks, Christian! I just forbid that in exhale. Please check the latest Git version for compilation issues and crashes, I'll update the documentation and will tag this as release 1.0.4 on the weekend.
Chris
Reply #169
It's time to compile binaries of latest git  and run 1.0.4 beta on a large number of files to check for possible crashes or any other issues.
Reply #171
exhale support unicode?
Reply #172
Apparently it doesn't :( I checked myself. Will take a look at this later.
Chris
Reply #173
exhale version 1.0.4 has been released today, see
https://gitlab.com/ecodis/exhale/-/releases/v1.0.4
exhale 1.0.4 - Change Log
- finalized basic joint-stereo and TNS coding functionality, quality and stability fixes
- exhaleApp: support for 32000 Hz with CVBR mode 1, added '-v' version command
- exhaleLib: completed audio quality fine-tuning for very tonal and transient signals
- compilation: support for MinGW (issue #5) & cmake (via CMakeLists files, issue #6)
This release completes my general audio quality tuning for all CVBR modes. I'm not planning further major changes in bit allocation, only sample-specific adjustments if severe audio quality issues are reported (that is, for samples other than Fatboy, Girl, and Linchpin). The next release will focus on reducing the mean bit-rate resulting from 32-kHz audio coding with mode 1 (which is slightly higher than the targeted 64 kbit/s stereo at the moment) by 1 or 2 kbit/s without affecting the audio quality. I'll also try to add automatic downsampling to 32 kHz for that mode, which I wasn't able to finish in time for this release, and take a look at the Unicode issue reported by m14u yesterday.
By the way, I call this release the "E" release since this is the fifth public release of exhale. E is also the initial of a former colleague of mine at Fraunhofer, a kind and gentle person and brilliant mind who passed away two weeks ago, much too young. I dedicate this exhale version to him.
Chris
Reply #174
amm... unicode issue is not a exhale's issue , but "john's exhaleapp.exe win64 in wine64".
