HydrogenAudio
Hosted Forums => foobar2000 => General - (fb2k) => Topic started by: scitrek on 2009-09-10 13:07:14
Title: Regular expressions on tags
Post by: scitrek on 2009-09-10 13:07:14
Hi all. I have a little problem with my soudtracks collection and my iPod. As you probably know, scrolling a list very fast (through the click-wheel) in the artist / album selection pops up a letter selection menu. Since all my soundtracks files have the prefix "[OST]" in the album field, I cannot use this tool on my iPod to select a letter in the soundtrack album list.
Now, I've noticed tha in the iPod manager preferences there's the possibility to automatically edit the tags when uploading to the iPod. Right now, the album property is set to
$if2(%album%,'('None')')
Is it possible to rewrite this line to something like: when the tag starts with "[OST]" add the seventh character in front. So an album tag like "[OST] Titanic" would become "T [OST] Titanic" and so on.
Thanks so much!
Post by: scitrek on 2009-09-10 13:27:42
I don't know why I missed the scripting page on the FooBar wiki... I read the documentation, and I came up with this:
$if(%album%,$if($substr(%album%,0,5) IS '[OST]',$left(7,1)'pippo'),'('None')')
Does it seem right? How can I test it?
Thanks again!
Post by: marc2003 on 2009-09-10 13:39:53
a few problems...
IS is part of the search query syntax so can't be used here. use $strcmp.
[ is a special character you'd need to wrap it in single quotes. just like the ( in the example above.
try this
$if(%album%,$if($strcmp('['OST']',$substr(%album%,0,5)),$substr(%album%,7,7) %album%,%album%),'('None')')
you can test by accessing the properties dialog of the file. right click "album", select "format from other fields", copy/paste the code and you'll get a preview.
Post by: scitrek on 2009-09-11 01:50:26
Thank you very much for the revision, it works perfectly now!
