Topic: Matroska Tags (Read 1563 times) previous topic - next topic
Matroska Tags
I hope this is the right forum.
I'm currently working on creating mka audios that contain an AAC stream, an Opus stream, and a SRT stream. Purpose is for people who are hearing impaired but still benefit from audio, they just need captions to help them make out some of the words. The AAC and Opus streams are same content, it's just AAC decoders are not included out of box on some operating systems (those usually have Opus at this point)
Anyway - figuring out Matroska tags took a little effort but I can finally generate an xml python that when added to the MKA makes sense when I view it in VLC - I have one Tag TargetTypeValue of 70 that has metadata about the collection and one tag with a TargetTypeValue of 30 that is specific to the track itself.
But I want to also add replay gain data, and my understanding is that proper replay gain may vary from lossy format to lossy format, so I can't just add the replay gain data to the Tag node with TargetTypeValue 30.
I'm guessing I have two add to more Tag nodes, one specific to the AAC and one specific to the Opus. That would also let me store the encoder information. But I have trouble with the Matroska tag documentation, it is very confusing.
How do I create a Tag node that adds metadata specific to the AAC stream (always first added) and another one specific to the Opus stream (always second added)?
Thank you for suggestions.
Re: Matroska Tags
I figured it out - I can generate separate metadata xml files with just the specific tags for the streams and then use mkvmerge to add them via
mkvmerge -o final.mka --tags 0:aac.xml --tags 1:opus.xml tmp.mka
of course assuming the aac is stream 0 and the opus is stream 1 which they always are in my usage.
Re: Matroska Tags
Oh and it seems mkvtoolnix is the only application that actually reads the tags correctly, seems media applications don't understand how to parse them correctly into how they display tags, so I guess the benefit is just academic for now.
