Topic: Load DSP Presents with arguments  (Read 765 times) previous topic - next topic
Hi everybody
I search for a long time a way to implement it to load automatically DSP chain presents with the foo_scheduler. Didn't got a response in the therad of the plugin., so I'm asking if it is possible to add arguments in the command line to load a chain present?
If it's not possible to load differents DSP chain presents with the scheduler plugin, I'll use the run command line to run the foobar application with specific arguments. But how would those look like? Didn't found anything..
Thank you for your help!
skinsuite
Re: Load DSP Presents with arguments
Try
foobar2000 /command:"Playback/DSP settings/the_preset_name"
I'm sorry, it's not clear to me?
"C:\Program Files (x86)\foobar2000\foobar2000.exe" -Playback/DSP settings/stereo
Seems like i do it wrong How has to look it?
Skinsuie
I meant
"C:\Program Files (x86)\foobar2000\foobar2000.exe" /command:"Playback/DSP settings/stereo"
but I tried and I cannot make it work, so this suggestion was wrong.
Yes like this it doesn't work..
Anybody else got an idea?
Thank you very much!
Well I researched and thought this will be the solution:
"C:\Program Files (x86)\foobar2000\foobar2000.exe" /RunMainMenuCommand("Playback/DSP settings/5.1")
Hmmm but no.. Any idea for the right command?
