Alex, BRAVO man. New version is really slick. This will be useful for people (it pops up if you send wrong commandline parameters) -
Album Art Downloader XUI version 0.1.0.0
**** Only the first three parameters may be un-named ****
Usage: AlbumArt.exe [options]
Option names may be preceded by a / or a -
Options:
/artist Artist to search for (/artist "Artist Name")
May be abbreviated to /ar (/ar "Artist Name")
Parameter name may be omitted
if this is the first parameter ("Artist Name")
/album Album to search for (/album "Album Name")
May be abbreviated to /al (/al "Album Name")
if this is the second parameter ("Artist Name" "Album Name")
/path Default path to save art as (/path "\Art\Folder.jpg")
May be abbreviated to /p (/p "\Art\Folder.jpg")
if this is the third parameter ("Artist Name" "Album Name" "\Art\Folder.jpg")
The following variables can be used in paths:
%artist% Artist searched for
%album% Album searched for
%name% Name of the image found
%extension% Default file extension for the image
%source% Name of the source where image was found
%size% Dimensions of the image
/f Provided for backwards (/p "\Art" /f "Folder.jpg")
compatibility only. When
specified, the value is
appended to the path.
/autoclose Closes the search window after (/autoclose)
a saving. To avoid closing, use
Save As.
May be abbreviated to /ac
/sources Searches only the specified (/sources "Amazon,Coveralia")
sources. Others are disabled.
Separate sources with commas.
May be abbreviated to /s
/exclude Does not search the specified (/exclude "Local Files,Google")
sources. Separate sources with
commas.
May be abbreviated to /es
For backwards compatibilty, the
parameter "/ae off" can also be
used to exclude "Local Files".
The click-and-hold-to-preview is a very nice added feature. GREAT JOB!
Incidentally, I found out this computer at work....EATS IT big time on .NET 3 apps 15-25% CPU usage and 100+ MBs RAM just sitting there...ugh.
Only 2 things I can think of at the moment to request -
1. Option to put the image info below the thumbnail instead of to the side
2. A 'Stop All' button at the top of the sources column
