Topic: Protracker (P41A) plugin (Read 1553 times) previous topic - next topic
Welcome
Can someone write plug into foobar P41A-enabled format.
Currently I use to play these files Deliplayer but it would be nice if foobar is served.
Here sample.
Thank you.
You can use Prowiz to unpack them for now. If you must insist that a MOD player support every one of the 5 million different packing schemes that various Amiga software utilized, you'll have to wait until I clean up Prowiz and turn it into a generic unpacking step in foo_dumb.
Re: Protracker (P41A) plugin
Was anything ever added to foo_dumb to handle packed tracker files?
No, but foo_openmpt54 supports some packed tracker formats that foo_dumb did not. Maybe give it a try?
I never wanted to touch Prowiz code, because it's a giant mess of static code with static variables and direct file access throughout, making it a mess to convert into a library that can operate directly in memory and operate multiple concurrent instances if necessary.
